Author Topic: The uBeam FAQ  (Read 675898 times)
Re: The uBeam FAQ
« Reply #1125 on: November 22, 2017, 10:11:04 pm »
Makes sense after all, the power infrastructure is already there, and their beamforming tech has got to be great for targeting passing cars!
And it cuts out the need to drive to the take-away for fast food - fresh flash fried squirrels will be literally falling out of the trees.
Online mikeselectricstuff
    • Mike's Electric Stuff
Re: The uBeam FAQ
« Reply #1126 on: November 22, 2017, 11:47:40 pm »
I wonder if she's approached Tesla for EV chargers yet?
I waiting for the announcement of uBeam transmitters on power poles beside the road for charging cars.
Powered by the solar frickin' roadways, obviously.
Day Job: Mostly LEDs
Offline Cyberdragon
Re: The uBeam FAQ
« Reply #1127 on: November 23, 2017, 02:06:22 am »
Can someone please troll tweet Meredith with that idea to see if it's practical?  ;D
Someone drives by in a Tesla truck and the pole transformer just explodes. >:D
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline sdpkom
Re: The uBeam FAQ
« Reply #1128 on: November 23, 2017, 10:44:16 am »
Not sure how you get that number for the phone. If at 150 dB that needs 0.005m^2 to get 5W, let's be super generous and say 10W with 50% efficiency of receive conversion, so 0.01m. An iPhone X is about 7.5 by 15cm so 0.01125m^2.
...  more transmit area can be applied to compensate for that loss and maintain the same power incident on the receiver, up until the point you run out of transmit area.
I'm not sure this is true,
Assuming some level power, say 145dB, 150dB, whatever.... is deemed unsafe
The power level at the receiver side cannot exceed this safe limit, can it?
So If the effective phone size is 70cm^2, and the maximal power density that's still safe (on either side) is 150dB than 7W can really be transmitted.
But...
Assume the transmitter is actually transmitting a few watts in 0% humidity.
A day later, a receiver receives 1% of the power,  can the transmitter increase it's output 100X?
It can't, for two reasons
1. To do that it must know what is the exact reason for the decline in received power is, if the reason is that my body absorbs 99% of the power I hope it's not going to increase it. Knowing the exact reason why something delivers less power, takes a human a day's work in the lab and is beyond the current capabilities of devices.
2. Such dynamic range means your costs are X100 higher, if your "dry day" cost is anywhere above $10, your wet day costs are sky high.
Offline PaulReynolds
Re: The uBeam FAQ
« Reply #1129 on: November 23, 2017, 09:07:37 pm »
But...
If someone were to follow the safety rules, I would agree that you should not have a power higher than that at any point - at transmitter, receiver, or inbetween. In that presentation, uBeam appeared to be saying there were no limits anymore. That was a surprise to me, and to those in the industry who chair that type of ultrasound safety group that I have spoken to since.
As sound travels, it loses power as heat, so as long as you do not increase the focus effect faster than you lose power in the air, you do not exceed even if you start at the limit. This is pretty standard in ultrasound medical imaging, and usually the numbers work out that the highest intensity is at the focus (and what the FDA usually worries about, in most cases that's the Mechanical Index).
And yes you're correct that at some level of transmitter area increase, you hit a hard physical limit. Is that limit within the range of normal use? What do you sacrifice as you add more transmit area? Loss of efficiency and reduction in the number of targets that can be served?
I think your numbers are a bit extreme, but yes temp and humidity do affect sound velocity and attenuation, for example here's some data for audio frequencies from NASA.
https://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19670007333.pdf - note responses aren't linear
And a simple tool for calculating loss (based on audio, but my recollection is that it's close enough)
http://www.sengpielaudio.com/calculator-air.htm
Best to worst cases you're looking at maybe 1 to 1.5 dB/m difference. Significant, but not 100x.
As Dave and others have pointed out - distance, orientation, and being obscured by hands etc are likely to be the much more significant issues.
« Last Edit: November 23, 2017, 09:43:28 pm by PaulReynolds »
The following users thanked this post: sdpkom
Offline EEVblog
Re: The uBeam FAQ
« Reply #1130 on: November 23, 2017, 10:13:01 pm »
Unless they are absolutely sure about this, then it's a very deliberate act of misleading investors.
They are showstoppers that make the entire idea demonstrably ludicrously impractical.
Offline EEVblog
Re: The uBeam FAQ
« Reply #1131 on: November 25, 2017, 05:36:08 am »
This is deeply disturbing.
From their due-diligence pack for investors.
They claim FCC/FDA approval and ZERO safety risk!
« Last Edit: November 25, 2017, 05:37:45 am by EEVblog »
Offline djos
Re: The uBeam FAQ
« Reply #1132 on: November 25, 2017, 06:32:06 am »
It looks like someone has found something actually useful to use ultrasonic technology in.
https://www.fanaticalfuturist.com/2017/11/worlds-first-ultrasound-3d-printer-prints-and-assembles-electronics-in-situ/
Offline amspire
Re: The uBeam FAQ
« Reply #1133 on: November 25, 2017, 06:56:15 am »
It make me angry. I have had to recently deal with some old people who are loosing their eyesight with things like macular degeneration and diabetes.
Hearing becomes everything. You would hope that if uBeam becomes anywhere near to implementation, rules limiting continuous ultrasound levels in home/office/public situations to 80dB would be implemented.
Where is the due diligence from the investors? I hope the only future uBeam lawsuits will be from mislead investors, and not from damaged people.
The only good news is that uBeam promises become more and more feeble with each round of fundraising. 0.6W at 1 meter? Have you got to keep the phone pointing to the transmitter at a distance of 1 meter to just maintain charge? In what way is that "freedom of movement"?
Offline StillTrying
  • Country: Broken Britain
Re: The uBeam FAQ
« Reply #1134 on: November 26, 2017, 01:38:42 am »
0.6W-1W @ 1m+ is the first figures we've seen, and shows how close we were.
Magnetic Resonance - Risk of heating up surrounding metal objects.
uBean  -  Risk of heating up the whole room.
Re: The uBeam FAQ
« Reply #1135 on: November 28, 2017, 05:00:43 pm »
Is it just me it's not working for, or did someone at uBeam decide that investor video shouldn't have been set as publicly available? Looks to have been taken down.
« Last Edit: November 28, 2017, 06:11:08 pm by PaulReynolds »
Offline StillTrying
Re: The uBeam FAQ
« Reply #1136 on: November 28, 2017, 09:43:48 pm »
Yep, the investor video has been taken down. Perhaps they have enough investors now, hiding the evidence, or they've shut up shop. :horse:
Offline sdpkom
Re: The uBeam FAQ
« Reply #1137 on: November 29, 2017, 11:30:43 am »
It was surprising it was publicly available. If you're not raising funds from the public... why show your pitch to the public (including the likes of us, as well as potential competitors).
They also have a potential risk of slander lawsuits by competitors and regulatory bodies.
Therefore, no surprise it was removed.
Offline StillTrying
Re: The uBeam FAQ
« Reply #1138 on: December 07, 2017, 07:38:29 pm »
« Last Edit: December 08, 2017, 06:45:03 pm by StillTrying »
Offline Dubbie
Re: The uBeam FAQ
« Reply #1139 on: December 07, 2017, 11:24:06 pm »
Not sure I am confused or if this has already been posted here:
3. uBeam $20,000,000
Round: Series B
Description: uBeam is a wireless power startup that transmits power to charge electronic devices over-the-air.
Industry: Consumer Electronics, Hardware, Internet of Things, Wireless
Date of funding: 15-Nov
Total equity funding: $30,750,000
From here:
http://www.latechwatch.com/2017/12/10-largest-la-startup-funding-rounds-november-2017/9/
Looks like they have another few million to squander.
Offline l0rd_hex
  • I'm a master of karate and friendship for everyone
Re: The uBeam FAQ
« Reply #1140 on: December 13, 2017, 09:59:56 pm »
It's kinda sad, reading a story like this: http://www.al.com/news/huntsville/index.ssf/2017/05/daniel_lewis_built_her_own_art.html where someone has built something to help mankind and giving it away for free versus Meredith who's blowing millions of VC money on ham and twitterrhea
"I haven't paid taxes in six years, and I'm not getting busted by a damn sandwich." - Benjamin Franklin
Offline StillTrying
Re: The uBeam FAQ
« Reply #1141 on: December 27, 2017, 12:55:13 am »
Offline EEVblog
Re: The uBeam FAQ
« Reply #1142 on: December 27, 2017, 02:21:14 am »
It's gone.
Probably no shortage of copies available for journalistic purposes.
Offline EEVblog
Re: The uBeam FAQ
« Reply #1143 on: December 27, 2017, 02:30:27 am »
Offline StillTrying
Re: The uBeam FAQ
« Reply #1144 on: December 28, 2017, 01:03:13 am »
Re: The uBeam FAQ
« Reply #1145 on: December 28, 2017, 08:53:11 am »
Offline Howardlong
Re: The uBeam FAQ
« Reply #1146 on: December 28, 2017, 07:19:16 pm »
That's probably a paid marketing episode.
A total waste of money then. :horse:
https://www.engadget.com/2017/12/26/fcc-approves-first-wireless-power-at-a-distance-charging-syste/
That is just as much bullshit as ubeam - FCC approval means nothing but a stock price jump
 https://liesandstartuppr.blogspot.co.uk/2017/12/energous-and-fcc-approval-for-mid-range.html
Can anyone point me to the docket in the FCC database where this has been formally approved? I can’t seem to find it.
Offline Fungus
Re: The uBeam FAQ
« Reply #1148 on: December 28, 2017, 08:33:36 pm »
Batteriser also has FCC approval. Just sayin'.  :popcorn:
Re: The uBeam FAQ
« Reply #1149 on: December 28, 2017, 09:50:51 pm »
Found it https://apps.fcc.gov/oetcf/eas/reports/ViewExhibitReport.cfm?mode=Exhibits&RequestTimeout=500&calledFromFrame=N&application_id=B6rKOmC6QGs13hWdV%2FM5%2Fg%3D%3D&fcc_id=2ADNG-MS300
One snippet from that - they're using a 90 watt PSU...
https://www.digikey.co.uk/product-detail/en/delta-electronics/MDS-090AAS15-BA/1145-1011-ND/3909354
Also, WTF is the point of a wireless charger that requires the device being charged to be located in a specific, small area?
The Charging Zone of the MS-300 is up to 90 cm for Client Devices placed in front of the MS-300, i.e. Client Devices within 90 cm of the front of the MS-300
may be charged; Client Devices further than 90 cm or outside an angle of ±35° from a centerline projecting from the front of the MS-300 will not be charged
« Last Edit: December 28, 2017, 09:56:49 pm by mikeselectricstuff »
