eer the client requested a 100 MHz scope be available, so it looks a bit funny if I set up a scope that say's on it's decal 50 MHz and then tell them it is 100 MHz
Ah, yes. I see. I guess that begs the question of if you knew you were to supply a 100 MHz scope for a Client, why you purchased a 50 MHz unit instead. But you don't have to explain yourself to me. At least I understand your dilemma now.
- Mark
P.S. Black electrical tape? ![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
well it goes like this: I work for a BOG standard company who design and make air con and cooling packs for vehicles. The companies electrical competence dates back to pre WWII ie: we still use power resistors to reduce 24 V to 12 V but then if your equiping a military vehicle (we do a lot for MOD mostly indirectly) you want it to be robust.
We messed up on a design (nothing new) and need to verify for EMI as they go nuts over that.
We are of course very ill equiped and the way it went was thus:
Eng.: Simon have you got an oscilloscope in the QC dept. ?
me: No but I have one at home if we need one.
Eng.: It's ok I have one upstairs, do you know how to use one
me: (having thought well yes you stupid **** I just tyold you i OWN one) sure
Later he called me over and showed me his sons ex hameg 303-4 and said "show me how to use it" after some fiddling trying to get a trace out of it as the buttons had obviously been randomly pressed and I'm no scope geek I just use them he said to take it away and get it working and to let him know.
He came back later and explained that the client need a 100 MHz scope but at least we have "this one" that does 30 MHz and maybe 50 (yes for a pure sine wave only i bet) so I suggested my 50 MHz digital. took it in next day and he was impressed and said we'd best use it instead, I explained that I could probably get it to work at 100 MHz although obviosly as this guy is not on the ball (he's the one that can't draw a non abiguos evaporator coils drawing and generally get stuff right let alone understand finer things) he has not thought yet that the client will find it odd that we present a scope with 50 MHz on the face and say it will do 100 MHz, after all the mess ups we have made I know they will think we are as nuts as we are
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
oh well will prove to be fun, better than the usual work routine, if only they would take electronics control more seriously I may have wider scope in the job, being a goods in QC inspector is boring
![Undecided :-\](https://www.eevblog.com/forum/Smileys/default/undecided.gif)
