Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Alu enclosure SD card hole: Need "rubber closing mechanism"
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Alu enclosure SD card hole: Need "rubber closing mechanism" (Read 1606 times)
Martin F
Regular Contributor
Country:
on:
June 15, 2018, 08:17:14 am »
Hi all,
In our data logger we have a small hole for inserting an SD card as part of our end plate.
We're looking for low cost rubber closing mechanisms for this - I've seen these on other products, e.g.:
https://www.kvaser.com/whatever-your-data-logging-needs-kvaser-now-has-a-memorator-to-suit/
However, I've been unable to find these anywhere - I guess I lack the right name for searching for it.
Any tips?
Thanks,
Martin
Logged
ebastler
Super Contributor
Country:
Re: Alu enclosure SD card hole: Need "rubber closing mechanism"
Reply #1 on:
June 15, 2018, 10:12:55 am »
I have not come across these as a standard part. Would assume that they are custom made, just like the plastic enclosure of the example product you showed?
Logged
amv
Contributor
Reply #2 on:
June 15, 2018, 10:33:04 am »
Hej Martin F
Hvis du prøver at google "sd card reader rubber protection" dukker der et par stykker op.
Ellers prøv
www.modcover.com
og søger på "sd card port silicone rubber dust cover" er der i hvertfald en der
håber det kan bruges
Jan
Hi Martin F
If you google "sd card reader rubber protection" a few will come up.
Otherwise try
www.modcover.com
and search"sd card port silicone rubber dust cover" They have at least one.
Hopes this helps
jan
Logged
Marco
Super Contributor
Country:
Reply #3 on:
June 15, 2018, 12:28:18 pm »
If you don't need long term availability, you could mill a slot and hole for a dust protector from a Sony Xperia. Those are all over ebay.
Logged
thm_w
NiHaoMike
Super Contributor
Country:
"Don't turn it on - Take it apart!"
Reply #4 on:
June 15, 2018, 07:12:08 pm »
3D print some out of TPU?
Logged
JohnMc
Contributor
Country:
Reply #5 on:
June 16, 2018, 02:05:28 am »
Not sure if something like this might work for you? Had seen USB ports like this figured someone must do SD card.
http://www.polamco.com/micro-sd-and-dual-sim-card-receptacle/
Logged
ikrase
Regular Contributor
Country:
Reply #6 on:
June 16, 2018, 03:05:46 am »
Maybe cast some silicone into milled molds?
Logged
Richard Crowley
Super Contributor
Country:
KJ7YLK
Reply #7 on:
June 16, 2018, 03:37:46 am »
You could mold your own out of Sugaru.
Unbeatable combination of quick, easy, and cheap.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
