So VPAM is half-baked? (I'm not defending it or bashing it. I really have never used it seriously enough to know).
VPAM is great if you have to calculate an expression exactly as you see it on paper, because that's what it's designed to do, and is really more suited to a large display with edit etc.
So if you have 20*Log(1/2) you actually type is as you see it, with the Log key coming first.
But I find that's a PITA for everyday calculations.
For example, if you wanted to just calculate 1/2 and then decided to take the log of that after the fact, then you have to press an extra key (=). Because VPAM expects the operand to follow the operator.
So it's extra key presses for simple stuff.
e.g.
Log 2 is now 3 key presses: Log 2 =
instead of just two key presses: 2 Log
So I find the older non-VPAM system more intuitive when you
aren't working with a paper equation.
It's just more intuitive to have single operand operators like Log, Sin, SQRT etc work instantly on the current number.
I know why they did it, it was for the students, so the calculator with just like you see the equation on paper. Hence the acronym "Visually Perfect Algebraic Model".
Dave.
