Author Topic: Take a look at these NASA Apollo Mission Control Console close-up view displays.  (Read 3940 times)
Offline SilverSolder
I remember a cheap sci-fi movie from the '50s, where the crew of a rocketship traveling to Mars or somewhere smoked inside the spacecraft.  Indoors!
I would not be surprised if they smoked in their space suits.  Flicking the ash off would be difficult.  Then I guess they'd have to eat the butt.
This is back when men were men etc.
Offline dcac
And having a nice cup of coffee too. (sorry for the poor quality I guess preserving this cutout footage never was a priority)
The following users thanked this post: Ed.Kloonk
Offline artag
In the early days of stock exchanges the video displays were all driven using analogue video delivered over coax cable. However the video signal was merely there to deliver a blank screen, the actual data was done using TELETEXT decoder chipsets in the TV sets, with each page being assigned to different types of display. This gave a very robust data transfer, yet the actual hardware itself was simple enough and available off the shelf, and you could select any page at any time, and it would come up in sequence. The only change they did to the text standard was to use the entire frame of video to handle text, not just the top 3 lines of the screen normally blanked by the retrace circuit, so that they could transmit the entire 1000 page magazine very rapidly.
I had a job interview with the part of Logica that built those systems for the LSE around '85. The guy there told me that the reason they used teletext (apart from the good reasons you list) is that it's a broadcast standard : the same data goes to all the terminals at the same instant, not sent to one terminal after another by however fast a terminal i/o processor you might choose to use. Yes, the pages are sent serially one after another, but any given page is sent to all simultaneously.
As a result, there's no way the traders could complain that one person was getting data faster than any other. They all got it at the same time, down to the bit.
Offline AlbertL
By coincidence  i stumbled across this earlier today
Note that at 1:49 in Fran's video we see a row of large flatbed plotters in front of the first row of consoles.  That's the first time I've seen them in the Apollo MOCR - I believe they were the main graphical display device in Project Mercury as well as military missile tests in that era.  I'm wondering if they were an interim solution for one mission before the the large-screen display was fully operational.
