Author Topic: Switched reluctance motors will save the planet?  (Read 4350 times)
Offline EEVblogTopic starter
« on: July 27, 2020, 08:19:38 am »
Someone sent this in for debunk as a "scam".
Not putting this in the Dodgy Technology section, because it sounds more like over the top startup marketing wank than anything else?
https://turntide.com/
https://www.prnewswire.com/news-releases/software-motor-company-smc-has-rebranded-to-turntide-technologies-as-it-brings-the-smart-motor-system-to-market-to-solve-for-energy-inefficiencies-in-todays-motors-and-reduce-carbon-emissions-301097158.html
I haven't done any more thought or investigation than skimming the video.
« Last Edit: July 27, 2020, 08:21:11 am by EEVblog »
Offline Zero999
  • 0999
Re: Switched reluctance motors will save the planet?
« Reply #1 on: July 27, 2020, 08:31:14 am »
Over 47% of the world’s electricity is consumed by analog motors. These legacy motors haven’t fundamentally evolved since the 19th century, and they waste half the energy they consume.
The only motors less than 50% efficient are those really cheap and crappy ones found in toys and cost tens of pence. :palm:
Most decent sized motors have much higher efficiencies, often above 95%.
Offline Kleinstein
« Reply #2 on: July 27, 2020, 08:48:14 am »
The efficiency of motors depends a lot on size. Larger motor are quite efficient, like > 90%. 50% efficiency is more like a thing of very small cheap motors like 100 W range.
I point where quite a bit can be saved is with speed control in things like fans and pumps, though with pumps there are limits to this as the pump part often also need a certain speed range. Here a switched reluctance motor can very well compete with a conventional induction motor with electronic drive / inverter. The 3rd competing technology with even slightly higher efficiency (especially in small size) are brush-less permanent magnet motors.
Switched reluctance motors are already available for quite some time - I remember a shop vacuum cleaner that is available from before 2000, though relatively expensive. The control needs a little effort, but no AI or anything magic or new.
Offline wraper
  • Country: lv
« Reply #4 on: July 27, 2020, 09:00:51 am »
I can add shaded-pole induction motors with 15-30% efficiency. Consume about half of max power without any load at all. Run hot as hell. Used in almost every convection oven fan, axial AC fans and in most of 120/230V AC water pumps in washing machines and dishwashers.
Offline Zero999
  • 0999
« Reply #5 on: July 27, 2020, 10:13:49 am »
That's true. I forgot, there are applications where efficiency isn't the most important design goal.
Offline Ranayna
« Reply #6 on: July 27, 2020, 10:17:25 am »
Hmm, would it even matter, in regards for efficiency, if a convection oven fan motor runs hot?
It would mainly run when the oven is running anyway, and that has only one job: getting hot :p
I am not all that familiar with the construction of washing machines and dishwashers. But both use warm water. Would motor heat not at least partially heat the water, and therefore reduce the load of the heating element accordingly?
EDIT: Regarding the claims... Those generalized claims of amazing potential savings remind me of the Batterizer  >:D Not exactly *lies*, but waaaaaaay over exaggerated.
Offline wraper
  • Country: lv
« Reply #7 on: July 27, 2020, 10:59:46 am »
Motor is located outside the oven and only it's shaft goes inside. The only thing it heats is surrounding air, so all of the heat is wasted. The other big downside is that because of running very hot, bearing lifetime is significantly reduced.
Again, motor itself is not water cooled. Heat goes into ambient air. Also in washing machine motor is used for draining only AFAIK.
« Last Edit: July 27, 2020, 11:02:58 am by wraper »
Offline wraper
  • Country: lv
« Reply #8 on: July 27, 2020, 11:06:16 am »
Actually it is quite important in all applications I listed, maybe besides washing machine. Motor usually runs constantly during appliance operation, so quite a lot of power is wasted.
Online tom66
« Reply #9 on: July 27, 2020, 11:17:39 am »
If the drain pump is anything like my washing machine it's only draining for about 20-30 seconds in the middle of the cycle and at the end of the cycle.  The power consumption of the heating element and drive motor are far more significant.  And those AC brushed universal motors can be quite efficient, well above 70% and only consume around 200W at the full speed spin.
I know my Bosch dishwasher uses a more efficient water pump motor, it sounds by the description like a brushless type. It uses around 80W when the heating element isn't running. Which given the water pressure is decent, it also has to spin the arms via that pressure and still have enough to dislodge food etc from the plates.  And it uses 900Wh for a full load on the economy setting and 1.4kWh on the intensive 70C setting.  Surprisingly efficient.
« Last Edit: July 27, 2020, 12:07:34 pm by tom66 »
Online coppice
« Reply #10 on: July 27, 2020, 11:23:52 am »
With the temperature at which some small squirrel cage motors run, fire avoidance doesn't seem to be an important design goal, either.
Online coppice
« Reply #11 on: July 27, 2020, 11:27:45 am »
The nicest thing about switched reluctance motors is how quiet they can make a lot of currently noisy home appliances. There were prototype kitchen appliances, like food mixers, with switched reluctance motors around in the 80s that were super quiet. Sadly the market preferred cheaper over quieter.
Offline Zero999
  • 0999
« Reply #12 on: July 27, 2020, 11:42:42 am »
Not really, fan oven motors only use a tiny amount of power, compared to the oven itself and the same is probably true for dishwashers. A quick Google found this one only consumes 22W. Cut that in half and we have a power saving of only 11W. The efficiency of the appliance could be improved more by better thermal insulation, than changing the motor.
https://www.espares.co.uk/product/es1548541?utm_source=google+shopping&utm_medium=shopping&utm_campaign=google+shopping&gclid=EAIaIQobChMIxYSRpqnt6gIVb4BQBh2v6w9FEAQYAiABEgLU-_D_BwE
I don't think I've ever seen one catch fire. They're normally fitted with a thermal cut-out, which is usually one-shot. No doubt power could be saved by changing them for switched reluctance motors, but they tend to be the smaller, cheaper motors which only use tens of Watts, so it's not worth it. Using more copper in the windings and a copper rotor, rather than aluminium would probably give more bang for buck, than changing to switched reluctance.
Anyway, this is off-topic. The manufacturer discussed in the original post is talking about motors which use 47% of the world's electrical energy i.e. large motors. The tiny motors used in fan ovens and dishwashers are a drop in the ocean. It's total BS that half of the energy used by the world's motors is wasted.
« Last Edit: July 27, 2020, 11:47:27 am by Zero999 »
« Reply #13 on: July 27, 2020, 11:09:17 pm »
Probably means diddly squat in the global scheme of things though?
Offline wraper
  • Country: lv
« Reply #14 on: July 27, 2020, 11:13:48 pm »
Considering they are in most of homes in somewhat developed countries, IMHO it matters. Say it makes 0.1% difference in overall home electricity consumption. Globally it means energy needed for powering a few small countries.
They are also used in microwave oven fans BTW.
« Last Edit: July 27, 2020, 11:21:53 pm by wraper »
« Reply #15 on: July 28, 2020, 03:39:39 am »
Microwave oven fans would be the epitome of the cases where it doesn't matter. i.e. you have an already high load (1000W) working for only a few minutes a day.
Offline james_s
« Reply #16 on: July 28, 2020, 04:02:30 am »
Shaded pole motors are used everywhere, bathroom vent fans, desk fans, AC powered muffin fans, furnace and boiler draft inducers, medium sized fountain pumps, anywhere that requires a cheap low power AC motor. There are other types of induction motor such as PSC or even 3 phase motors that can easily be scaled down into these sizes, they just typically aren't because it costs so much more.
My ~15 year old Maytag Neptune washing machine has a switched reluctance motor. It works fine although these days it seems like VFDs are cheap and good enough that ordinary 3 phase induction or BLCD motors probably make more sense. If they banned shaded pole motors I suspect PSC and BLCD would take over most applications where they are now used.
Offline filssavi
« Reply #17 on: July 28, 2020, 04:24:45 am »
Now I didn’t watch the video, but I can assure switched reluctance machines are absolutely a thing, the operating principle is the same as the BLDCs however instead of magnet the rotor is has a highly asymmetric radial reluctance profile.
You also have synchronous reluctance (synrel) machines that work more like PMSMs but use the same principle. There are even hybrid machines where some torque is due to magnets and some torque is due to reluctance.
Performance wise they are (for most Typical applications) strictly worse than permanent magnets machines, and typically(though not necessarily) have a terrible power factor (0.5-0.7 lagging) however they cost much less and you don’t rely on a single country for rare earths magnets. They are still better than induction machines though as there are no rotor copper losses
That said these type of machines are extremely rugged, as the rotor is basically a hunk of solid steel, they don’t have brushes, rotor bars that can break, magnets that demagnetise etc just stamped steel laminations bonded together.
Offline Jay_Diddy_B
« Reply #18 on: July 28, 2020, 04:30:07 am »
Switched reluctance motors have been around a long time, at least 40 years.
The Dyson digital motor used the Dyson vacuum cleaners and hand driers are switched reluctance motors.
They are very similar to stepper motors. They tend to by noisy and have pulsating torque, the rotor tends to 'snap' from one position to another.
There is a Goodness Factor for electric motors:
More here:
https://en.wikipedia.org/wiki/Goodness_factor#:~:text=The%20goodness%20factor%20is%20a,efficient%20magnetic%20levitation%20induction%20motors.&text=From%20this%20he%20showed%20that,likely%20to%20be%20relatively%20large.
This helps explain why switched reluctance motors are good.
Ae is relatively large, short windings of thick wire.
Le is the length of the electrical circuit, it can be short.
W is large high RPM
They also need a driver.
This goodness factor explains why large machines are better, more efficient than small ones. If you scale the linear dimensions, the areas, Ae and Am scale with the linear dimensions squared, Le and Lm increase proportional to the linear dimension. So goodness gets better.
It also explains why switch mode power supply transformers are better than line frequency ones for a given size.
The idea that the switch reluctance motor will save the planet seems like a lot of hype to me.
Jay_Diddy_B
The following users thanked this post: WattsThat
Offline filssavi
« Reply #19 on: July 28, 2020, 04:33:27 am »
Switched reluctance machines require a VFD just as much as a BLDC, the main reason they are not used in white goods and general consumer crap is not the drive requirements, but just the higher cost, that is not justified by any real advantage. Powe density is fine and good, however there is plenty of space inside the whashing machine. Efficiency wise the difference, at the low power levels we talk about is negligible (you will have maybe few watts difference if that)
Offline WattsThat
« Reply #20 on: July 28, 2020, 04:46:11 am »
What an absolute load of marketing wank.
As someone on the front lines of VFD technology, all I can say is, thanks for the laugh.
Switched reluctance motors have been around for years in appliances. Fine for low power, constant torque applications.
On much larger, industrial scale, synchronous reluctance motors (synRM) and their drives have been built for years by ABB. Here’s a video that goes back to 2013, the drive has since been a replaced by the ACS880 which can control asynchronous, permanent magnet and synRM motors, all with the same firmware. 0.5 to several thousand kilowatts. Same drive. They’ve been building them for years. The only difference is that synRM is a variable torque, not constant torque machine. Power savings over standard induction machines is worthwhile, it does provide a quick payback.
Yawn. Nothing to see here. Move along.
« Last Edit: July 28, 2020, 05:11:40 am by WattsThat »
Online bdunham7
« Reply #21 on: July 28, 2020, 04:48:28 am »
My car has a version of the switched reluctance motor.  They don't say much about it, and it is sometimes referred to as a 'synchronous motor' but it has that characteristic little quiver if you creep very slowly up a steep incline like my driveway.  Other than that it is very smooth and efficient, which I assume is due to the tweaking of the very large liquid-cooled electronic motor drive module.
Offline Jay_Diddy_B
« Reply #22 on: July 28, 2020, 05:00:02 am »
There are some techniques in the motor design that can reduce the torque pulsation. There are also some techniques that can be applied to the driver, similar to micro-stepping in a stepper motor to reduce the pulsations.
In the conditions you describe, high torque, low speed, the output power is low, since power = torque x angular velocity. The efficiency is low under these conditions.
Jay_Diddy_B
Online tom66
« Reply #23 on: July 28, 2020, 06:43:26 am »
I've noticed an interesting phenomenon with my Golf GTE (plugin hybrid.)  In electric mode, if you creep up a hill at very low speed, it will eventually stop.  In this mode it seems to use about 5kW.   It seems as if the electric drive does not like you using creep for long periods of time.  You can press the pedal again and it will creep once more but stop after 10 seconds.  Whereas it will creep endlessly on flat surfaces.  If you actively use the accelerator it will always go faster than this creep setting, so I wonder if it is microstepping and that is inefficient and there is a thermal/time limit here for a reason.
Offline tszaboo
« Reply #24 on: July 28, 2020, 07:24:57 am »
Different appliances have different design goals for the motors. For example I have a blender, that is probably used a few hours over it's entire lifetime. So, you can design in a very powerful, efficient motor, with diagnostic, variable drive, controller etc. Or find the cheapest rotating thing, and attach a blade for it. The first one would be acceptable for a blender for an ice cream factory I guess, but I'm using mine maybe once a week.
Actually the EU commission recently have been spending a lot of time optimizing the efficiency of white goods. They had new lays for vacuum cleaners and the controversial kettle law. So there is a push to reduce wasted energy.
These guys probably found out that many 20-30 year old building appliances, HVAC could be more efficient with these motors. (I've studied about them in university BTW) Good for you, start replacing old motors, make money. It's actually very nice, that they correctly identified the market niche for their product.
The following users thanked this post: filssavi
