Found myself lately ditching standalone lab instruments in the favor of DIY test platforms. By test platforms I mean measuring instruments/generators improvised out of random MCU devboards, all thrown together in a container, and all the boards talking with a PC through a USB hub. Power is either from USB, or by wall adapters, so no lab power supply either.
Main reason is that it's too hot outside to add in the same room a couple more hundred watts of heat produced by the lab instruments (talking about a home lab). Second reason is that I don't like the hum noises coming from the cooling fans each instrument has. Most of the time is spent anyway writing software, so running the lab instruments during all this time doesn't make much sense.
Thinking of making a fanless adjustable power supply. Or maybe just some standalone testing modules: voltmeters, LDOs of fixed voltage (but isolated), a logic probe with a few LEDs, an Arduino with a display as oscilloscope, and anchor them all together with whatever project board has to be tested, for example by using sticky tape and bigger plastic container to keep all in one box.
Anybody in a similar situation?
