I have seen in videos where people will calibrate to a certain frequency range, but then to get a closer look, they change to a narrower span without recalibrating. So lets say I calibrate my VNA for 28MHz to 29MHz to look at a variety of 10m crystals. If I want to look at the S21 at 0° phase for Rs calculations or the 45° phase shift frequencies for measuring Lm and Cm, do I need to recalibrate every time I zoom in to a 10kHz span and look at a crystal within this 1MHz range, or will the results still be close enough if I leave the calibration for the 1MHz span loaded?
Thanks!
