Author Topic: Stock Electronic Image FAILS  (Read 286122 times)
0 Members and 13 Guests are viewing this topic.
Offline lowimpedance
  • Watts in an ohm?
Re: Stock Electronic Image FAILS
« Reply #275 on: January 30, 2018, 02:03:09 am »
I love these pictures...
Me too, always brightens up the day with a good  :-DD.
There is no limit to Stupid in the Universe. :D
How true how true.
Offline GreyWoolfe
  • NW0LF
« Reply #276 on: January 30, 2018, 02:15:08 am »
It's think that smoke must be some really strong drug that eliminates pain...
Well, as a real solderer female told me, never wear tights and a miniskirt when soldering. (Not that I've tried it) That is a sure recipe for YIKES!!! and prancing round the room in pain.  :scared:
I always do my soldering in shorts, just too hot in Florida for long pants.  I have learned to ignore the pain.  For some reason, though, SWMBO is offended by the smell of the burning hair.  Go figure.
Offline Falkra
« Reply #277 on: January 30, 2018, 06:04:16 am »
Don't turn it on...
..take it apart.
« Last Edit: January 30, 2018, 06:06:34 am by Falkra »
Offline CatalinaWOW
« Reply #278 on: January 30, 2018, 05:33:37 pm »
Can someone tell me where I can find a soldering iron like these? Looks practical and easy to use :-DD
Just mislabeled.  Documentary evidence of lightning fast super technician doing diagnosis while magic smoke is still present.  Forceps used to keep guilty component from escaping.
Offline Red Squirrel
« Reply #279 on: February 03, 2018, 07:52:02 pm »
Don't turn it on...
..take it apart.
Hope that's not line voltage, to be resting his hand so close to the terminals like that!    That meter is just in "eco mode".  :-DD
Offline Cyberdragon
« Reply #280 on: February 03, 2018, 10:53:38 pm »
What kind of breaker panel would be horizontal? :wtf:
*BZZZZZZAAAAAP*
Voltamort strikes again!
« Reply #281 on: February 03, 2018, 11:48:39 pm »
That looks more like a DIN based control panel.  Motors and stuff.   Though I have seen electrical panels mounted sideways.  IMO I think it uses up too much space that way, I prefer vertical with the main at the bottom so it's easier to reach in an emergency.  But it really depends on the house and how the hydro comes in.  Often they place it whichever way is more convenient for that.
Offline glarsson
« Reply #282 on: February 04, 2018, 12:40:00 am »
Offline Cyberdragon
« Reply #283 on: February 04, 2018, 01:18:01 am »
In a country outside of the USA?
http://www.elteknik-ab.se/wp-content/uploads/2016/02/20160210_163245-1.jpg
But...that's still vertical on the wall. The one above is clearly horizontal and on the floor as the meter is sitting on it.
*BZZZZZZAAAAAP*
Offline timelessbeing
« Reply #284 on: February 04, 2018, 01:24:48 am »
it's so that the electrons don't fall out.  :)
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #285 on: February 04, 2018, 01:30:43 am »
Yes, but it's not a breaker panel.  It's some sort of machine chassis that happens to have some breakers on it.  There are a few breakers, but most of the other stuff looks like terminal blocks and relays/contactors and whatnot, all mounted on DIN rail.  Wouldn't surprise me if it were mounted horizontally.
-Pat
« Reply #286 on: February 04, 2018, 02:09:09 am »
-Pat
Yeah think that's a control cabinet.  It may even be on a work bench.  Once everything is routed then it's mounted on a board and shipped to the customer and then connected up.
Offline EEVblog
« Reply #287 on: November 21, 2018, 03:55:25 am »
GOLD!
The following users thanked this post: xrunner, tooki
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #288 on: November 21, 2018, 03:57:13 am »
GOLD!
Hahaha is it supposed to be soldering? Maybe they are shorting out the probe and melting it.  :-DD :-DD
The following users thanked this post: bsudbrink
Offline Leiothrix
« Reply #289 on: November 21, 2018, 04:16:09 am »
GOLD!
That's what happens when you probe mains connected equipment without being mindful of ground loops...
« Last Edit: November 21, 2018, 04:19:55 am by Leiothrix »
The following users thanked this post: tooki, bsudbrink
« Reply #290 on: November 21, 2018, 04:18:05 am »
Is... that a scope probe?  :-DD :-DD  :-DD
Offline Cyberdragon
« Reply #291 on: November 21, 2018, 05:38:43 am »
Was... it clearly arced over and burned up. :-BROKE ;D
*BZZZZZZAAAAAP*
Offline basinstreetdesign
« Reply #292 on: November 21, 2018, 06:04:25 am »
 :-DD  WOW and I didn't know that scope probes would do that!   :-DD
STAND BACK!  I'm going to try SCIENCE!
Offline Domagoj T
  • Country: hr
« Reply #293 on: November 21, 2018, 06:21:49 am »
Ok, confession time.
A while ago a TV crew came to my workplace, and wanted some shots of "people looking busy". They had an eye on this particular piece of electronics and wanted me to fiddle with it, so I took a screw driver to "adjust" the trimpot, but in hindsight, the shot was probably much to wide to catch the trimpot, so it probably just looks like I'm very concerned why a board doesn't work while I screw around it.
The segment aired on national TV.  :-[
« Reply #294 on: November 21, 2018, 07:01:56 am »
GOLD!
Look at it. That's definitely magic smoke.
Offline McBryce
« Reply #295 on: November 21, 2018, 07:43:18 am »
From now on I'll be turning on the extractor fan before I probe something with my scope!
McBryce.
Online Fungus
« Reply #296 on: November 21, 2018, 08:19:25 am »
Must have floated his oscilloscope.
Offline free_electron
    • SiliconValleyGarage
« Reply #297 on: November 21, 2018, 12:44:51 pm »
GOLD!
that's what happens when your probe tip is too wide : the magic smoke escapes ...  :-DD
Offline janoc
« Reply #298 on: November 21, 2018, 02:52:34 pm »
I am fairly sure that the quality of their "100% online" education matches the quality of their advertising. That's what you get with "100% online" - no labs so nobody to show you how a scope probe works ...
Offline Cyberdragon
« Reply #299 on: November 21, 2018, 10:17:32 pm »
They give you a stupid pictoral diagram and expect you to practice with a stick. :-DD
*BZZZZZZAAAAAP*
