Author Topic: Stock Electronic Image FAILS  (Read 291314 times)
Offline schmitt trigger
  • Country: mx
Re: Stock Electronic Image FAILS
« Reply #325 on: May 23, 2019, 01:32:03 am »
People with rediculous solid state rubbish are always oblivious to the simplest solutions... ::)
Is that a kludged, belt-driven exciter???  :wtf:
Offline windsmurf
« Reply #326 on: May 23, 2019, 07:14:54 am »
The following users thanked this post: xrunner, Naguissa
Offline McBryce
« Reply #327 on: May 23, 2019, 07:37:22 am »
Why use an anti-static mat, when you can just use a spare PC Motherboard?
McBryce.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #328 on: May 23, 2019, 08:00:56 am »
At least he's holding the iron correctly...  Baby steps, people - baby steps!
-Pat
Offline NiHaoMike
    • Facebook Page
« Reply #329 on: May 23, 2019, 12:35:52 pm »
Given the motherboard is old enough to have IDE and multiple PCI, maybe it's a scrap being used to avoid burning the table?
Offline VK3DRB
« Reply #330 on: May 24, 2019, 11:03:38 am »
Check out 8:30 to 9:00
 :palm:
No wonder there was a nuclear accident. It all started when they were trying to jump start a 1N914 diode. The engineers clearly didn't know what the Fukushima they were doing.
The following users thanked this post: schmitt trigger
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #331 on: May 26, 2019, 01:34:18 am »
Just found this looking at DMMs on Ebay.  :-DD
Offline timelessbeing
« Reply #332 on: May 26, 2019, 02:07:22 am »
You know it's a quality meter when the positive jacks are black.
Offline Bud
« Reply #333 on: May 26, 2019, 03:35:03 am »
Black probe in voltage jack, red one in current jack. Black probe is over the red probe, that is V/I = R what is on the display, i do not see anything wrong with it   :-+
The following users thanked this post: xrunner, tooki
Online xrunner
« Reply #334 on: May 26, 2019, 06:00:23 pm »
Tee hee hee.  :-DD
Here's another one from Ebay seller.
Step 1 - Heat solder joint
Step 2 - ... Aw hell forget that one, let's do this one!  :-DD
Online xrunner
« Reply #335 on: May 26, 2019, 11:57:54 pm »
Well the el cheapo meter - we have a choice of black or yellow. The associated pics can help us understand where we use it.
We have a nice soldering pic, for some reason. Must be to show off their other product - the impenatrable clear plastic gloves that let you touch the hot soldering iron. The melted plastic helps keep your skin free of contamination for the rest of the day.
Also, checking some sort of industrial strip. Fine.
Plus, don't forget your wrench. Make it a Big Wrench. Real big, so they'll really think you know what you're doing. With the meter, which is ... somewhere.
Offline windsmurf
« Reply #336 on: May 27, 2019, 12:10:48 am »
The user is about to yell the brand name of this meter.
The following users thanked this post: tox3, bsfeechannel, Teti, Naguissa, Daixiwen, InductorbackEMF
« Reply #337 on: May 27, 2019, 12:12:31 am »
The wrench pic has a car engine in the background. It's showing that the meter can be used for automotive troubleshooting. I don't have a problem with it.
« Reply #338 on: May 27, 2019, 12:13:52 am »
:-DD
Online xrunner
« Reply #339 on: May 27, 2019, 12:14:18 am »
At least use the 20A port!   :-DD
Online xrunner
« Reply #340 on: May 27, 2019, 12:15:44 am »
Using a wrench for the prop?
Uh, OK.  :o
Offline Domagoj T
  • Country: hr
« Reply #341 on: May 27, 2019, 04:45:45 am »
Too expensive. They designed two different silk screens for the two colors. What do they think, that I'm made out of money?
Online xrunner
« Reply #342 on: June 15, 2019, 02:06:12 am »
Hmmm ...
Offline Red Squirrel
« Reply #343 on: June 15, 2019, 04:15:55 am »
Ah yes, AC capacitors they store voltage in AC.
Offline Psi
« Reply #344 on: June 15, 2019, 04:20:25 am »
I saw a video recently where they attached a car jumper cable clip onto a PLCC socket.
But i cant remember were i saw it or i would post a link.
Offline ElektroQuark
    • ElektroQuark
« Reply #345 on: June 15, 2019, 04:23:34 am »
I love them! They even reverse text marks on them at V frequency! It's in the negative phase now!
Offline kjr18
« Reply #346 on: June 15, 2019, 06:25:07 am »
It was somewhere on this forum. A documentary on Fukushima's reactor failure or something like that.
Offline Cubdriver
  • Nixie addict
« Reply #347 on: June 15, 2019, 06:35:17 am »
Yes  - it was something about the tsunami and Fukushima, and yes, somewhere here.
-Pat
Offline Cubdriver
  • Nixie addict
« Reply #348 on: June 15, 2019, 06:40:19 am »
Hmmm ...
I don't think I'd want to be holding a 50V rated electrolytic that had 220VAC across it.  Seems like just begging to lose a fingertip or two when that puppy grenades.  (Though on further reflection, the print on the cap is mirrored - maybe it's from opposite world where DC means ac and 220 is less than 50.)
-Pat
Offline bsfeechannel
« Reply #349 on: June 15, 2019, 02:01:42 pm »
How to solder your tweezers to the PCB and other problems.
The following users thanked this post: Naguissa
