Author Topic: Stock Electronic Image FAILS  (Read 282886 times)
Online Ian.M
Re: Stock Electronic Image FAILS
« Reply #1025 on: June 05, 2024, 01:18:50 am »
Yes, it is a fail, albeit a subtler one than usual.
Normally you'd tack down only one of the pins at that stage of soldering so either way would work.
. . . if you don't care where pin 1 is!
The following users thanked this post: Fungus
Online SiliconWizard
« Reply #1026 on: June 05, 2024, 03:28:39 am »
Forcing a specific orientation for pin 1 is oppressive! 8)
The following users thanked this post: 5U4GB
Offline PlainName
  • Country: va
« Reply #1027 on: June 07, 2024, 03:42:41 pm »
Not exactly a stock image, but I guess government issue might count:
The fence should be designed to avoid a person becoming caught over or against it and unable to remove themselves (mantraps). This is done by design and spacing of fence components - Figure 2 shows fence designs that avoid mantraps. The gap between the security fence and the outer fence should be either less than 200mm or more than 1000mm NOTE: Barbed wire or razor wire must not be used as part of or adjacent to the fences (see below)
Offline McBryce
« Reply #1028 on: June 07, 2024, 06:13:18 pm »
Other than that mistake (and the fact that they forgot to delete the two fence supports in the picture on the right). I don't see how the fence on the right would work. If I can climb that outside wall and stand on it, I could easily clear the electrical fence completely by jumping over it. Or have I completely misunderstood the diagram?
McBryce.
Offline PlainName
  • Country: va
« Reply #1029 on: June 07, 2024, 06:26:28 pm »
They'd probably be in the dark as much as you if they'd thought about it :)
Online Fungus
« Reply #1030 on: June 07, 2024, 10:36:06 pm »
How do electric fences work anyway? Can't you just wear gumboots?
(Or put a plastic sheet on the ground, or jump up onto it, or...)
Offline helius
« Reply #1031 on: June 07, 2024, 11:26:58 pm »
Electric fences are typically meant to keep animals in or out. Without opposable thumbs, they would have trouble putting on rubber boots or throwing plastic sheets.
Concertina wire is used when the goal is keeping people in or out. People can understand the risk they face of getting sliced to ribbons and bleeding out, animals cannot. Many animals also have thick hides and would not be much bothered by concertina wire.
Online Fungus
« Reply #1032 on: June 08, 2024, 01:33:50 am »
So electric fences around military bases are just a movie prop?
« Reply #1033 on: June 08, 2024, 07:38:01 am »
No, they're there to keep animals out. You really don't want herds of deer wandering across your runway, as a random example
Offline McBryce
« Reply #1034 on: June 08, 2024, 10:56:29 am »
So those fences around prisons are to stop the inmates from making beef burgers? I've learnt something new today.
McBryce.
Offline Zero999
  • 0999
« Reply #1035 on: June 09, 2024, 07:40:35 pm »
According to Amazon's YouTube advertisement, it's possible to power a mains lamp, with a couple of potato cells. :palm:
Online amyk
« Reply #1036 on: June 09, 2024, 08:13:22 pm »
That must be a really "hot" potato! :-DD
Interesting choice of PPE and only one of them wearing it.
More seriously, you can get low-voltage filament style LED lamps, but they certainly require far more power than two potato cells.
Online xrunner
  • hp>Agilent>Keysight>???
« Reply #1037 on: June 09, 2024, 08:58:11 pm »
Why does the kid need safety glasses but not mom?  :o
Offline magic
« Reply #1038 on: June 10, 2024, 05:38:22 am »
You can get low voltage incandescent bulbs too. Maybe there's more potatoes hidden under the table.
Offline Bud
« Reply #1039 on: June 10, 2024, 06:10:21 am »
It is a 3-phase potato power source, 4 wires on the bench is a giveaway.
Offline Kjelt
« Reply #1040 on: June 10, 2024, 01:10:11 pm »
Oh you guys, they are cooking the potatoes with main voltage, the lightbulb is the series resistor to lower the amps, unfortunately the potatoes were so wet it was a short, hence the bulb giving light  :-DD
Offline BILLPOD
« Reply #1041 on: June 10, 2024, 07:56:28 pm »
Did youse guys realize there is a thread about electric fences?
Offline McBryce
« Reply #1042 on: June 11, 2024, 01:07:42 pm »
Yes, in fact I was considering joining it, but I'm still on the fence about it.  ::)
McBryce.
The following users thanked this post: Ed.Kloonk
Offline martin1959
    • Tele-Commies
« Reply #1043 on: June 11, 2024, 02:16:13 pm »
There exists a current probe which even can measure current in fiber optic cables.
2287979-0
I am wondering how many kilovolts it takes to force few amperes through them fiber optic cables...
« Last Edit: June 11, 2024, 02:30:04 pm by martin1959 »
The following users thanked this post: Sal Ammoniac, xrunner, Bud, helius, Kleinstein, BlownUpCapacitor
Offline Kim Christensen
« Reply #1044 on: June 11, 2024, 03:50:40 pm »
At least it doesn't have a display lit up showing some reading like 90 Amps...  ::)
A humorous Ad would have it clamped around the fiber showing zero current, and the operator with a confused look on their face.  ;D
The following users thanked this post: martin1959
Offline Kjelt
« Reply #1045 on: June 30, 2024, 08:08:51 am »
Double crimp connectors to connect two wires.
But like this it is not going to work
The following users thanked this post: BlownUpCapacitor
Offline NiHaoMike
    • Facebook Page
« Reply #1046 on: July 06, 2024, 02:54:29 pm »
Online xrunner
« Reply #1047 on: July 06, 2024, 02:57:42 pm »
Shame on Adafruit!  :-DD
Offline NiHaoMike
    • Facebook Page
« Reply #1048 on: July 06, 2024, 03:43:53 pm »
The nail polish really makes it look like it was staged by a software engineer.
Online Fungus
« Reply #1049 on: July 06, 2024, 05:27:54 pm »
A 7x7 TQFP has...?
