Author Topic: AntiStatic Straps perished  (Read 847 times)
Offline johnhTopic starter
« on: January 24, 2021, 02:36:44 am »
Going through a box of accumulated stuff
Came across these, there were 10 of the wrist straps, seven had perished
Thought it strange that most had perished but a few had survived
Salvaged the crocodile clips  and the lugs with snaps
Offline james_s
Re: AntiStatic Straps perished
« Reply #1 on: January 24, 2021, 04:22:19 am »
I'd have expected the elastic to deteriorate rather than the insulation but I suppose it's down to the composition and storage conditions. Is it possible one of those is older, or was exposed to UV, or ozone?
Offline james_s
« Reply #2 on: January 24, 2021, 04:44:04 am »
I have a love/hate relationship with plastic. It can be wonderful stuff, but it can also be a real pain and start decomposing for no apparent reason. It's a real problem with with older cars as trim pieces shrink and get brittle. I had a TDS3000 scope that was in great shape but became super brittle and started crumbling. Nothing I could do about it but eventually found a broken scope with a good housing.
Offline Halcyon
  • Global Moderator
« Reply #3 on: January 24, 2021, 07:30:08 am »
Same thing happens with old white plastic Cisco Aironet access points and the old green Catalyst 10/100 switches.
