Author Topic: Static-ness of a AC sheet(fibro) as a workbench.  (Read 1888 times)
Offline Ed.KloonkTopic starter
  • Cat video aficionado
« on: May 01, 2013, 03:25:21 am »
Let me spell that..   Ess haitch eee eee tee. Sheet.
Had to use shelf on a all-metal rack as a bench at work. It had a 16mm thick 900x450mm AC fibro sheet laying on it because the metal shelf under it was the welded open wire type so someone planted the fibro sheet on there to at least make the shelf useful.
It was near a powerpoint and all I needed to do was recharge a laptop. But it got me wondering, if was doing anything remotely electronic on that surface, what are the static characteristics of fibro?
iratus parum formica
Offline PeterG
Re: Static-ness of a AC sheet(fibro) as a workbench.
« Reply #1 on: May 01, 2013, 03:51:43 am »
Fibro being a severe health hazard is the only characteristic i would be interested in. :o
Regards
Testing one two three...
Online NiHaoMike
    • Facebook Page
« Reply #2 on: May 01, 2013, 05:21:49 am »
http://en.wikipedia.org/wiki/Fibro
The newer stuff should be pretty safe.
« Reply #3 on: May 01, 2013, 05:45:12 am »
If you have any worries wipe it down with fabric softener, and let dry. Place the cloth you use in a plastic bag and throw it away after wiping. Now it is clean, non static and fragrant for weeks.
« Reply #4 on: May 01, 2013, 06:01:52 am »
Thanks.  :-+
But I'm never going to clean it and/or make it stink pretty.
I'm certain I'd get called all sorts of derogatory names if someone caught me domesticating the place.
