Author Topic: Standard battery shapes  (Read 3164 times)
Offline akisTopic starter
« on: April 07, 2017, 06:32:27 am »
Why are common batteries cylindrical?
When you try to build, say, a battery pack for a laptop, or some other application, you lose space due to the awkward cylindrical shape of the most common and prolific batteries: AAA, AA, C, D, 18650, 26650...
Why can't they be made square ?
Just wondering
Offline IanB
Re: Standard battery shapes
« Reply #1 on: April 07, 2017, 06:38:40 am »
Well, they can be made square, for example 9 V batteries, or LiPo cells. A square or rectangular cell is called a prismatic cell.
But for other cells (a cell is a single unit of a battery), a cylindrical shape is easier to manufacture. Many types, such as lithium or NiMH are made by creating a roll of thin sheets. If you roll up a sandwich of thin sheets you naturally get a cylinder.
If you take other types of cell such as zinc chloride or alkaline, you want an equal distance from the center to the outside all the way round, and you want a container which is strong and easy to manufacture. Once more, cylinders come out as the most practical shape.
Offline David Hess
  • DavidH
« Reply #2 on: April 08, 2017, 10:48:31 pm »
A cylinder is also a good shape for holding pressure which would distort a prismatic container.
Offline james_s
« Reply #3 on: April 09, 2017, 08:11:18 pm »
The seals are a lot easier and more reliable with a cylinder too, round seal rather than corners that have to fit precisely.
Offline Kilrah
« Reply #4 on: April 09, 2017, 08:18:56 pm »
Prismatic Li-Po cells are ubiquitous, and will be used when filling the volume is considered important.
Apple are even known for manufacturing batteries with complex shapes for their thinnest machines - of course that has a cost, so for your bog standard machine most will just throw cheap 18650s and call it a day.
Offline Robomeds
« Reply #5 on: April 11, 2017, 01:51:34 am »
Li-ion cells also come in prismatic shapes (though Lipos have largely taken over that market).
Here is a Sanyo prismatic cell
http://www.megabatteries.com/item_details2.asp?id=17000&cat1=&uid=1753&vfpr=&vfbr=Sanyo&vfcat=Electronics+Electronics+Accessories+Power+Batteries&vfsku=3325495&vfbi=no_bid&sid=gpla&vfsku=17000&gpla=pla&gclid=CNy8g4elm9MCFQ6oaQodR08FAQ
I suspect it was just easier at the time to make higher capacity cells in cylindrical form.
Offline PointyOintment
  • ↑ I scanned my face
« Reply #6 on: April 13, 2017, 11:26:17 pm »
They are the same thing.
I refuse to use AD's LTspice or any other "free" software whose license agreement prohibits benchmarking it (which implies it's really bad) or publicly disclosing the existence of the agreement. Fortunately, I haven't agreed to that one, and those terms are public already.
Offline james_s
« Reply #7 on: April 14, 2017, 12:31:44 am »
They're similar. There are a multitude of different Li-based cell chemistries and physical construction. Most of the time when someone refers to "LiPo" they mean the high discharge current rated packs as used for electric RC vehicles.
The following users thanked this post: Kilrah
« Reply #8 on: April 15, 2017, 07:51:25 am »
I refer you to this guide by Davide Andrea (founder of a battery company, battery managment book author—you can look him up): https://www.reddit.com/r/electronics/comments/559b1b/liion_cell_terminology_oc/
Offline Robomeds
« Reply #9 on: April 27, 2017, 02:23:57 am »
When I was in the battery business it was understood they were chemically the same but not mechanically the same.  The mechanical differences can matter.
