I'm in the process of doing a "network refresh" at home - Retiring some old gear, installing new stuff. At the moment, everything has been lumped into a single Class C address range that has got a bit out of hand. There is no real order to things, servers have static IP's assigned, everything else comes off the DHCP server. At the moment, unless it's an IP I know is static, I have no idea if that device is sitting in the server rack or elsewhere in the house just by looking at the address.
I'm thinking about creating a Class B /23 scheme for the new gear (then migrate the remaining existing stuff over). In other words:
172.16.0.x - For servers, switches, access points, router, firewall etc... (basically all infrastructure/network related stuff)
172.16.1.x - For all other client devices such as computers, printers, cameras, phones, TVs etc...
Of course, I'm never going to actually need 510 IP addresses at home, but for years I've tried to create blocks of IP addresses which serve a certain "category" of device but there are always those devices which could fall into more than one category (or none at all). For example: I have a uRadmonitor which is neither a PC, nor server. It's just a device with an Ethernet port that does "stuff". Shortly I'm getting a solar inverter installed which would also be considered one of these miscellaneous devices.
What does everyone else (with an overly-elaborate IT system at home) do?
