Author Topic: Special solder for removing ICs  (Read 796 times)
Offline Peter TryndochTopic starter
« on: July 28, 2024, 02:51:26 am »
What is the name, or more specifically - what will get a hit on Ebay
for a special type of solder for removing components such as ICs.
It has a long plastic phase, so you flood the component with it and remove before the solder hardens.
Offline edpalmer42
Re: Special solder for removing ICs
« Reply #1 on: July 28, 2024, 03:09:41 am »
Are you thinking of ChipQuik?  It has a low melting temperature which means it stays liquid longer.
The following users thanked this post: NiHaoMike
Offline Helix70
  • VK4JNA
« Reply #2 on: July 28, 2024, 03:29:05 am »
Low temperature solder commonly has a high Bismuth content, like Chip Quik.
« Reply #3 on: July 28, 2024, 04:43:36 am »
Yesss Chip Quick, that's the name of it.
But man it ain't cheap.
Seems to be US made, and the listings don't mention shipping to Australia,
which more than likely will cost more that the product itself.
Think I'll give it a miss for now.
Offline ebastler
« Reply #4 on: July 28, 2024, 04:50:44 am »
You can look for generic no-name versions of that type of solder. It's Sn42/Bi58, melting point 138°C (280 F) is the commonly stated spec. Take a look at Ebay, Aliexpress etc., and you should find cheap options with affordable shipping.
« Reply #5 on: July 28, 2024, 06:11:22 am »
The trick is to know what to search with: Sn42/Bi58
I found some cheaper clone stuff.
They all seem to be in paste form.
Anyway I ordered some and will see how good it is.
Thanks for the tip.
Offline Psi
« Reply #6 on: July 28, 2024, 06:48:04 am »
Chip Quick also make normal solder. Don't make the mistake of thinking Chip Quick = low temp solder.
If it's low temp solder it will say low temp, or it will say a temp of around 140°C.
Normal solder is above 180C.
Online oPossum
Offline lowimpedance
  • Watts in an ohm?
« Reply #8 on: July 28, 2024, 10:40:28 am »
Mektronics in Sydney stock the small chipquick SMD removal kit, $36.08.
Expensive depends on the value of the device being repaired I guess.
Offline Shock
« Reply #9 on: July 28, 2024, 10:57:43 am »
It's about $20 on Digikey, I'd shop around.
« Last Edit: July 28, 2024, 11:04:47 am by Shock »
Offline edpalmer42
« Reply #10 on: July 28, 2024, 04:46:35 pm »
It's worth noting that if you search for "Chip Quick" you will limit your results.  The actual name is spelled "ChipQuik".
Ed
