I'm trying to increase output voltage on this apparatus/device. I would like to increase it to 53.5 volts so I can run a 4pill LD mosfet amp by DXworld. Any advice, looking for a Variable resistor to adjust like on most little power supplies. or is it more complicated like removing a resistor with a lower ohm rating? Any ideas. GaryLordsWay@aol.com thanks Gary.
