Author Topic: Solar freaking power hats  (Read 300 times)
Offline BudTopic starter
« Last Edit: August 04, 2024, 01:54:19 pm by Bud »
Offline Nominal Animal
Re: Solar freaking power hats
« Reply #1 on: August 04, 2024, 02:11:22 pm »
Let's do a back-of-the-envelope check: Let's estimate solar irradiance at best about 1 kW per square meter.  Small high-efficiency panels convert about 20% of that to electricity, or about 200 W/m².  12 W / 200 W × 1 m² = 0.06 m² = 600 cm² ≃ 93 in², i.e. you need a panel with a surface area of 600 cm² or 93 sq-in to produce 12 W.  That is a circular panel with a diameter of about 28 cm or 11" directed towards the sun.  As an annular ring with a 20cm/8" hole in the center, it'd have a diameter of at least 50cm.  The article states diameters between 56 and 61 cm (22" to 24"), so it seems plausible.
However, that size brim reminds me of a sombrero or an umbrella.
Gimmick caps with tiny fans and palm-sized panels have existed for at least three decades, though.
Offline Halcyon
  • Global Moderator
« Reply #2 on: August 05, 2024, 12:29:24 pm »
Just use an Android instead of an iPhone. Eliminates charge anxiety almost completely.
 :box:
I will say however, the current Apple laptops are absolutely phenomenal on battery. I no longer bother carrying around a charger/cable. I'd easily get 2 days use out of my Macbook.
