No, those switches have gotten poor over the years. The older versions used thicker casing parts, and thicker brass for the terminals and the internal construction, along with much beefier internal insulation. Take it apart, it is only 2 small screws, and you will find the internal small plastic carrier that is supposed to provide all the insulation. Old ones are pretty much filling the entire inside, not the little pip of plastic there is there now, and the metal was a lot thicker, with that lovely unsolderable chrome plate you had to scrape off to solder.
