Author Topic: SMD resistor code calculator  (Read 9931 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: June 19, 2010, 08:48:17 pm »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: SMD resistor code calculator
« Reply #1 on: June 19, 2010, 08:51:33 pm »
if only the through hole resistor have this kind of coding, we wont be needing the calculator and the color chart.
Offline RayJones
    • Personal Website
« Reply #2 on: June 19, 2010, 09:31:41 pm »
The thing that amuses me about surface mount resistors was the reason for using colour bands in the first place.
They couldn't print the numbers small enough.
Meanwhile technology has moved on, and now optometrists are doing a roaring trade  ;D
Online Zero999
  • 0999
« Reply #3 on: June 19, 2010, 10:47:32 pm »
I don't see the point in any of those calculators, I can remember the basic code.
An EIA-96 chart would be very handy though.
Offline charliex
  • Car Hacker
« Reply #4 on: June 20, 2010, 02:45:27 am »
they'd be for people who can't, or live by einstein's principle of never memorize something that you can look up. if its good enough for einstein ;)
Online Zero999
  • 0999
« Reply #5 on: June 20, 2010, 08:49:52 am »
I made no conscience effort to memorise it, it just happened. Remembering certain things is good because recalling is quicker than looking it up - I could tell you the value of a resistor before you even have chance to look at the chart.
  • Country: gr
  • User is banned.
« Reply #6 on: June 20, 2010, 08:59:47 am »
Nop , the color bands are still a great idea ...  you have  " many chances "  if you work with out schematic ,
to recognize the exploded - burned resistance, from the color bands.
alm
  • Guest
« Reply #7 on: June 20, 2010, 09:07:33 am »
Plus it doesn't matter how the resistor is oriented, you never have the problem that the value is facing the PCB or some other inaccessible area. I often have this problem with things like electrolytics and diodes. But this obviously is of no concern for SMD.
