Author Topic: Sourcing 100W solar panels  (Read 756 times)
Offline oliver602Topic starter
« on: February 18, 2021, 10:10:20 pm »
Hi all,
I have 78 cm X 183 cm space available for solar panels on a camper. I would like to fit 200 W.
I'm having trouble finding panels to make the most of the space available.
I initially found these 100 W panels that I could fit two of. But they are out of stock and quite expensive(?) at £139/$194 each. https://www.photonicuniverse.com/en/catalog/full/21-100W-12V-solar-panel-with-5m-cable-German-solar-cells.html
I did some searching on ebay and found these panels of similar dimensions and power at almost half the cost.
https://www.ebay.co.uk/itm/100W-100-Watt-Solar-Panel-Module-Folding-Strut-Controller-Fast-Battery-Charger/402137838557
My question is, would you trust the seller on the specifications and construction quality of these panels?
Offline NiHaoMike
    • Facebook Page
Re: Sourcing 100W solar panels
« Reply #1 on: February 19, 2021, 04:30:13 am »
Can you find a single panel around 200W of that dimension? 100W is no longer the "sweet spot" for lowest cost in small quantity.
« Reply #2 on: February 19, 2021, 07:37:24 am »
Hi all,
Shift something to fit a 325W panel.
https://www.ebay.com.au/itm/12V-325W-Solar-Panel-325-Watt-Mono-Caravan-Camping-Home-Battery-Charging-Power/153356517959
« Reply #3 on: February 21, 2021, 02:23:39 pm »
I found a 215W solar panel from Victron thats 80.8cm wide. I re measured and decided I could hopefully get away with a 81cm wide panel with some custom brackets.
