Unless you code in asm all the time IMO the cores don't matter that much. Of course if you are pushing for more in the same hardware/power envelope then yeah.
Agreed, I mostly write in C so the core is almost blind to me. Sure I use some inline asm but very rare. Plus I am not doing any real heavy processing so the processing power really isn't that big of deal. I run most of my stuff at around 4MHz which is plenty fast enough. No need to get up to 20MHz. I guess it will come down to onboard peripherals (which core shouldn't matter) and production qty price.Quote from: Hypernova on October 21, 2010, 09:00:23 pmUnless you code in asm all the time IMO the cores don't matter that much. Of course if you are pushing for more in the same hardware/power envelope then yeah.
