Author Topic: Show your Multimeter!  (Read 546467 times)
Offline SunRiver
Re: Show your Multimeter!
« Reply #950 on: August 04, 2021, 07:46:53 pm »
I really like these Meratronics, the photo shows the v530 still has a defect, but it is already under control.
It's good that you can still find new period parts in the old drawers.
Offline Shock
« Reply #951 on: August 05, 2021, 02:28:20 am »
These are my main meters. All were secondhand purchases (about $480 in total) over a few years.
Two pairs of Fluke 87V, and Fluke 189 (if I need logging). The Fluke 117 has built in LoZ and non contact voltage detection. The Fluke 112 on the right is more for portability and off bench use.
« Last Edit: September 01, 2021, 04:53:49 pm by Shock »
The following users thanked this post: Mortymore, Neomys Sapiens, Marco1971
Offline David Hess
  • DavidH
« Reply #952 on: August 05, 2021, 03:20:02 pm »
I recently moved my Tektronix DMM916 and Beckman RMS225 to a Nanuk 910 case.
Offline Neomys Sapiens
« Reply #953 on: August 05, 2021, 04:02:55 pm »
Needs more test leads/clips!  >:D
Maybe
A: the Pomona deluxe assortment
or
B: a pair of KLEPS2600/2700/2900/2900 each?
Offline David Hess
  • DavidH
« Reply #954 on: August 05, 2021, 04:58:29 pm »
I make my own test leads and am rebuilding them as I find them and move them to the case.  Somewhere I have another thermocouple converter also.  And if I can find my Beckman DMwhatever meter, I will need another case assuming it is worth keeping.
On the subject of test leads, since none of the shrouded plugs and jacks between my various meters are compatible, I take the stock leads, cut them in two, and add Anderson powerpole connectors so that I can swap the plugs with the test lead ends.
I'm currently rebuilding a Tektronix DM501A and will post pictures when that is done.  The Siliconix ADC has a blown input multiplexer, a common problem, so I am replacing the multiplexer and input buffer with external parts, and the performance of this 200 millivolt 4.5 digit multimeter should be considerably improved from stock because the original design of the Siliconix ADC suffered from poor linearity and likely noise.
« Last Edit: August 05, 2021, 11:01:38 pm by David Hess »
The following users thanked this post: Cubdriver, Neomys Sapiens
Offline duckduck
  • 20Hz < fun < 20kHz, and RF is Really Fun
« Reply #955 on: August 05, 2021, 07:19:18 pm »
My multimeters:
Fluke 26 III - Got it used a long time ago. It works. Reads a little low at high voltage (e.g. 300V) but otherwise solid. 600V CAT III. I was able to jam it in place in the shelf so it was my goto bench meter for a while. This is the meter that I use for electrical work at home (replacing outlets and light fixtures, etc.) and for checking prospective Craigslist purchases with e.g. measuring speaker resistance. I think that this is the same thing as the Fluke 79 III. Details: https://dam-assets.fluke.com/s3fs-public/7926____iseng0200.pdf
Fluke 179 - Bought it new with a couple of probe sets, case, magnet attachment (for hanging it to ferrous things), and thermometer about 10 years ago for around USD350. Really happy with it. 600V CAT IV. LED Backlight. Super-fast continuity beeper. Details: https://www.fluke.com/en-us/product/electrical-testing/digital-multimeters/fluke-179
HP 3455A - The "+" sign is missing in the photo due to scan frequency mismatch of the LED display and the camera. 5 1/2 to 6 1/2 digit multimeter. I got this one used off of Craigslist for USD60. What a steal! Like with all old gear, the line filter needs replacing. Also the fan is noisy, so I need to replace that, too. This is a beautiful piece of engineering from the late 1970s / early 1980s. Do yourself a favor and check out daqq's pictures of the inside of this thing. This meter cost more than a car when it was new. When you open it up, it becomes immediately obvious why. https://www.eevblog.com/forum/testgear/hp-3455a-teardown/msg324586/#msg324586
There's a nice little page on HP meters, "Evolution of Digital Voltmeters during the 1960 to 1980 Period": https://www.hpmemoryproject.org/wb_pages/wall_b_page_14b.htm
Gardner Bender GMT-312 - I expensed this at work to fly around with. It cost about USD15. It runs off of a single AA battery. It came with little mini probes with mini- safety-style connectors. I chose it because it was the cheapest multimeter I could find that was listed with a reputable testing agency (Intertek's ETL program, in this case). Details: https://www.gardnerbender.com/en/p/GMT-312/5-Function-Analog-Multimeter#
GW Instek GDM-8251A - This is my goto bench meter. Bought this one used on ebay for about USD250. This model was released around 2013. It is no longer sold. 120,000 counts (about 5 digits). Mine is in pretty good condition: incudes front and rear rubber baby buggy bumpers and  the folding bale. It is fanless. I keep it powered on all of the time. It has an "OUTPUT" button on the front that turns on/off the VFD and unlocks/locks the other keys. VFD is still fairly bright (set on 4 out of 5 as shown). I was looking for something that was supported by both sigrok ( https://sigrok.org/ ) and Test Controller ( https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/msg2981004/#msg2981004 ). It's got RS-232C, USB Device, and Digital I/O. There is PC software available for it. It has various very handy features such as a user-configureable averaging, relative measurements (makes it easy to see difference between two voltages or resistors), and can do basic math on readings (you could use this to display milliamps as you measured the voltage across a 14.7kOhm resistor). It does not measure capacitance, but I have a DER DE-5000 LCR meter. Details here: https://www.gwinstek.com/en-IN/products/detail/GDM-8251A
Pro-tip: don't keep alkaline batteries in your expensive test equipment! A leaky $1 battery can RUIN a fancy $380 multimeter. Use NiMH rechargeables or lithium primary (non-rechargeable) batteries as these have a better track record.
EDIT:
The Fluke 23/26/77/79 was the first "real" multimeter I ever used. It is what I think of when someone says "multimeter".
« Last Edit: August 06, 2021, 05:19:22 pm by duckduck »
Offline Ground_Loop
« Reply #956 on: August 10, 2021, 08:17:06 pm »
Here's most of them.
1243828-0
1243830-1
1243832-2
1243834-3
1243836-4
There's no point getting old if you don't have stories.
« Reply #957 on: August 10, 2021, 08:32:30 pm »
Interesting. How do you like the DP100? I wonder whether it is worth keeping on the aquisition list.
Offline Ground_Loop
« Reply #958 on: August 10, 2021, 08:41:39 pm »
It's terrible even when it works.  I got it as a throw-in from another purchase.  At the moment it does not boot properly.  I think I have a Power problem, but it's really not worth spending the time on.  Anyone want it?
Offline joeqsmith
« Reply #959 on: August 11, 2021, 09:05:29 pm »
My Fluke yellow clone.
It's very versatile.  Here I it is being used to measure the base current of a transistor.
The meter snobs will say this meter isn't useful and that I need a real Fluke to make any meaningful measurement.    The manual states its 250uA full scale.   Looking at the half way marker (note, this meter is pretty fancy and has a linearization scale), the meter reads spot on.  So it's small, super accurate and linear.   Not to mention, it comes complete with a portable lab.
« Last Edit: August 12, 2021, 01:05:24 am by joeqsmith »
The following users thanked this post: lowimpedance, rsjsouza, Cubdriver, Mortymore, duckduck, AaronLee
Online shakalnokturn
« Reply #960 on: August 12, 2021, 01:56:38 am »
This one is a keeper, the THM560 will be sold or bartered away.
I am very much interested to compare it with the more versatile Fluke 867, when I get my hands on one.
I used to own a THM565, (watch the SMD electrolytics around the RMS converter!) had to let go of it, didn't like the menus much, the scope is better than on the Fluke 867 though. I have one of those that I'm holding on to for now.
Yes definitely stick below 50 multimeters it leaves more volume for oscilloscopes.
Offline armandine2
« Reply #961 on: August 12, 2021, 06:46:01 am »
Another Fluke - my latest multimeter, the first one with a magnetic hanger.
In a closed society where everybody's guilty, the only crime is getting caught - Hunter S Thompson
Offline AaronLee
  • Country: kr
« Reply #962 on: August 12, 2021, 06:52:42 am »
You have that fancy switch in the lower left but didn't connect it. I want to see it switch at least between measuring current, voltage, and resistance. And then do one of your endurance tests on the switch.
Offline joeqsmith
« Reply #963 on: August 12, 2021, 08:18:17 pm »
With this meter now being close to 40 years old, I feel its proven itself mechanically.
While some may flaunt the ability to change the firmware on some meters,  my meter provides the ultimate approach.  The quick connect springs allow the real engineers (ages 10 and up)  to customize it for each particular measurement.    Say I want to measure 2-4mV.
Online lowimpedance
  • Watts in an ohm?
« Reply #964 on: August 13, 2021, 12:31:08 am »
I like the vintage bread board  :-+ . With all the modern fancy pants meters its easy to overlook the simple and sometimes most effective method of measurement !.... besides I like moving coil meters  :D.
and.......meter snobs indeed  :-DD
« Reply #965 on: August 13, 2021, 01:23:48 am »
In several German publications, this circuit appears under the name of 'Spannungslupe' (voltage magnifier). Example see
Messinstrumente und ihre Anwendung, W.M.Koehler, Franzis 1965
Offline joeqsmith
« Reply #966 on: August 13, 2021, 10:32:17 pm »
For that demo, I used the small 7-pin amplifier included with the kit.
I found the 160 in One in a local store that sells used items.  It came out after my childhood but I've been reading the manual for it and it seems like it was a pretty decent product.  I was no prodigy and many of the experiments would have been too advanced for me to understand at the age of 10.   I doubt I could do much more than wire the examples up.
« Reply #967 on: August 14, 2021, 07:03:38 pm »
Ah. I initially thought of this:
Offline armandine2
« Reply #968 on: August 14, 2021, 07:42:23 pm »
Regarding electronic project kits like Joe's 160 I have just tried googling for the publisher of a book I have, Experiments in Transistor Circuits second Edition 1971 (Bilderback and Kaminskie) - the book assumes access to their plug in modules. No voltmeter module from what I can see. Google didn't reveal anything to me other than their existence and now their address is a furniture store? I wonder if anyone remembers using or has their modules. The books appear to be rare.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #969 on: August 17, 2021, 06:16:08 pm »
1246883-0
The following users thanked this post: rsjsouza, Cubdriver, Gary350z, Mortymore, Neomys Sapiens
Offline ogdento
« Reply #970 on: August 24, 2021, 03:15:02 am »
wow, when I was a kid I had that same electronics kit that Joe posted a picture of.  I do remember the book that came with it... wish I still had it today!
The following users thanked this post: AaronLee
Offline electronicsengineer
  • Country: ru
« Reply #971 on: August 24, 2021, 06:12:24 am »
I used different multimeters, but I couldn't find a better FLUKE-(accuracy, ergonomics, speed, convenience) ...
Offline AaronLee
  • Country: kr
« Reply #972 on: August 24, 2021, 06:34:07 am »
I often dreamed of being able to buy that one. The one I had was only 65-in-1. Looking at the catalog of the 160-in-1 with the "fancy" integrated circuit, and thinking of what circuits might be possible with that, but never had the chance to actually try one out. These days I guess the kids use Arduinos and the like, along with various sensors, modules, etc.
I noticed those kits are available on Ebay. I assume mine was long ago donated to the thrift shop by my mother, as I never saw it after finishing university. Perhaps one day, just for kicks, I'll buy one of the 160-in-1 kits and build the circuits I never could as a kid.
Offline Cubdriver
  • Nixie addict
    • Photos of electronic gear
« Reply #973 on: August 24, 2021, 06:51:16 am »
I had its predecessor, the 150-in-1 in the late 70s and got a lot of enjoyment from it. If memory serves, over time I pilfered a lot of the components from it for later projects and at some point it went out with the trash.  Rat Shack had a lot of engaging stuff back in the day, between the XX-in-1 experimenter's sets and things like their P-box kits and the other Archer Kit stuff.  Then they devolved into a cell phone store.  Shame.
-Pat
Offline Vtile
  • Ingineer
« Reply #974 on: August 24, 2021, 08:22:41 am »
Here is my old trusty.
The CAT is definitely with those test leads!  :-DD
