Author Topic: Show your Multimeter!  (Read 538519 times)
Offline 4CX35000
Re: Show your Multimeter!
« Reply #850 on: February 22, 2018, 08:10:47 pm »
Micronta 18-Range Multitester was given to me by a widow whose late husband was a gas fitter. I think he many used it to test batteries and continuity. Sill boxed with the Radio Shack battery.
Also a Beckman Industrial 310 with the leather case which I used at work and they allowed me to keep it when I decided to leave for to join another company. It was a goodbye gift.
« Last Edit: February 24, 2018, 09:40:44 pm by 4CX35000 »
Offline sullyRD
« Reply #851 on: February 24, 2018, 06:05:34 pm »
Novotest TS-140 - Milano Ice Microtest 80 - Milano Ice Supertester 680R
upload photograph
« Last Edit: March 30, 2018, 01:10:32 pm by sullyRD »
To Build a Cenotaph, First Choose a Million Victims.
The following users thanked this post: PointyOintment, Inverted18650
Offline Vtile
  • Ingineer
« Reply #852 on: February 24, 2018, 08:49:11 pm »
Ice Supertester 680R, if you don't have one of these then get one, Brilliant analogue meter, which is still in production.
With all the leads and connectors.
picture hosting
With the Cassinelli milano Novotest TS-140 for comparison, these are made by different companies, Cassinelli is no more i believe.
Hey could you write a review of this one?
The following users thanked this post: Martin.M, PointyOintment
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #853 on: February 24, 2018, 10:48:07 pm »
First meter I have ever used - I recently inherited it from my dad. Quite featured for its time and the very large movement was enjoyable to use.
Where can I find it and accessories for sale? A few years ago I had a few websites that advertised it but the links went dead.
Offline Inverted18650
    • Test Gear Addicts
« Reply #854 on: February 25, 2018, 12:42:58 am »
Free gift with any purchase at HF about a year ago.
Offline bitseeker
« Reply #855 on: February 25, 2018, 12:47:29 am »
Yep, handy to have around for low-energy measurements. The built-in battery load tester is nice, too.
Offline rqsall
« Reply #856 on: February 25, 2018, 01:24:29 pm »
Hey SullyRD, do you have a source for the banana plugs? They seem to be of a rather odd size. I scored a Chinaglia Cortina a while ago on a flea market, but no probes came with it and I haven't been able to find them in the right size. They seem to be of the same size as the Novotest/ICE. Are they 3mm?
Sadly also the power supply to make the square wave generator in it work also didn't come with the unit, but that should be easy to fix.
Thank you.
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #857 on: February 25, 2018, 03:45:52 pm »
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
The following users thanked this post: rsjsouza, rqsall
Offline Calambres
    • Piso-Tones
« Reply #858 on: February 25, 2018, 05:39:51 pm »
I've got one of those ICE 680R multimeters since mid '70s and it is still in perfect use despite the obsolete and odd 3V battery (2R10).
This is a very fine instrument.
Offline nanofrog
« Reply #859 on: February 26, 2018, 03:08:21 am »
FWIW, Probemaster offers 2mm connectors for meters such as this (8043S = 2mm meter ends).  :-+
They ship internationally as well (no, I'm not some sort of paid shill; just a customer).
Offline rqsall
« Reply #860 on: February 26, 2018, 11:37:21 am »
If you need only the plugs, they have standard 2.0 mm plugs. I bought some from Distrelec, or you can search on Ebay.
Best regards
I have some 2mm banana plugs, but they're too small for the Chinaglia Cortina. 4mm is too large.  :-//
I guess they're not the same as the NovoTest/ICE after all then... Thanks anyway.
Offline Martin.M
  • in Tek we trust
    • vintage Tek collection
« Reply #861 on: February 26, 2018, 04:49:30 pm »
Keithley 179A TRMS Multimeter  :)
Offline Martin.M
  • in Tek we trust
« Reply #862 on: February 26, 2018, 04:50:26 pm »
Keithley 168 Autorange DMM   :)
and about my Fluke Oldie 8600AU:  may be from the first day, the serial No = 0030
« Last Edit: February 26, 2018, 05:11:12 pm by Martin.M »
Offline sullyRD
« Reply #863 on: February 26, 2018, 05:09:05 pm »
Thank you.
The leads on the Ice are 2mm x 15mm
Offline rsjsouza
  • Eternally curious
« Reply #864 on: February 26, 2018, 06:40:23 pm »
Thanks for the info on the leads of the ICE; I forgot about some probes I had purchased from Alibaba a while ago and the 2mm ends work really well with this meter.
« Last Edit: February 26, 2018, 06:41:56 pm by rsjsouza »
Offline boilerbots
« Reply #865 on: April 13, 2018, 05:03:12 am »
Hi have a 7150 but the front panel says Weston. I used to work at Schlumberger in a division that used to be Fairchild and there was all kinds of old test equipment there because this was the test equipment division. Anyway I never thought much about this meter until it started acting flaky and I found the threads about replacing the input line filter and some other improvements.
Offline Edison
  • Country: cz
« Reply #866 on: April 14, 2018, 04:17:06 pm »
I've had too many to count I think.
So send some of them, after having robbed me I have little and i have nothing to count   :-DD  :-DD  :-DD
Everything works as the weakest link in the chain
Offline david77
« Reply #867 on: July 28, 2018, 03:53:26 pm »
Haven't posted in a while but was still lurking.
While designing a small PSU for a RIAA amp I discovered that sometimes even seven meters are not enough. So I remedied that:
First something I wanted ever since it was discussed here, the Fluke 8060. I love it. If it had autoranging it would be perfect.
Then this Philips PM2517E just turned up. It was very dead and required quite a lot of surgery to be brought back, luckily the special IC's needed were available from the Netherlands.
I had the chance to get these two BEWA meters quite cheaply. They were made in Germany in the early 80ies, really some of the first
affordable digital meters available in Germany. They're just bog standard ICL7106 meters. Both meters are basically the same apart from accuracy specs.
There's BEWA's full size, full colour advert from the back of an Elektor magazine from 1984.
« Last Edit: July 28, 2018, 03:57:53 pm by david77 »
Offline georges80
« Reply #868 on: July 28, 2018, 05:06:08 pm »
Trip back to oz a month or so ago, found my first meter (45+ year ago purchase). Those were the days :)
cheers,
george.
Offline rsjsouza
  • Eternally curious
« Reply #869 on: July 28, 2018, 05:06:38 pm »
A few years ago I used to think about downsizing my collection and was always tempted to get rid of both my Flukes 8060 and 8062. However, they are so straightforward to use, still accurate decades after the last cal and incredibly portable that nowadays I just think they will be buried with me. :D
Offline Neomys Sapiens
« Reply #870 on: July 28, 2018, 11:30:00 pm »
As Fluke 8060's are becoming slightly scarcer all the time, please keep the TEA community current on your state of health and place of burial by way of this forum!
Offline Terry01
  • Country: scotland
« Reply #871 on: July 28, 2018, 11:37:14 pm »
I saw one of the 8060's on Ebay tonight for £85!  ???
Sparks and Smoke means i'm nearly there!
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #872 on: July 28, 2018, 11:42:05 pm »
My first at left image  and the last one reading a flat 9V battery
If one can make knowledge flow than it will go from negative to positve , for real
Offline ModemHead
  • No user-serviceable parts inside.
    • Mr. ModemHead
« Reply #873 on: July 29, 2018, 12:52:21 am »
On the left, is the first multimeter I ever owned, a Micronta VOM my folks gave me for my birthday.  On the right is the most recent multimeter I've acquired, a Simpson 360-2.
Oddly enough, they're both from the same time period (mid-70s).
Offline lacv2k
  • Country: pe
« Reply #874 on: August 10, 2018, 04:41:49 am »
Hello!
I saw the picture of you multimeter. Is the same I have!
Unfortunatelly I lost its manual. Do you have a digital copy of the information of this model (Micronta 22-194)?
Thank you in advance for your help!
Best regards
