![](http://i558.photobucket.com/albums/ss21/AF6LJ/Test%20Gear/IMG_0628_zpscejsyptj.jpg)
I recognisize that frequency counter!
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-tSGzNXv/0/L/IMG_8703-L.jpg)
Here are some of mine:
The 3440 that I recently re-capped and cleaned up.
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-ZFwTL89/0/L/IMG_8705-L.jpg)
A 3439 that worked for a bit when I first got it but then got flakey; it doubtless needs recapping at least.
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-KzCPHTS/0/L/IMG_8706-L.jpg)
A pair of 3470X's from eBuy; both need work (caps, etc.), but they're low on the priority list. I need to find a manual for the display section at least, and they don't seem to come up often.
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-GGwwD25/0/L/IMG_8707-L.jpg)
Workhorse handhelds; the 77-II I bought new 20+ years ago now IIRC, and I snagged a pair of the 27FMs from our favorite wallet-draining website a few years back when the .mil apparently surplussed a bunch of them. Got them for less than $50/pop with cases, leads and HV probes. The second is squirreled away upstairs and not readily at hand.
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-WfksWJ7/0/L/IMG_8709-L.jpg)
The ugly looking 3490A on the bottom came from Apex Electronics; I got it when I was out that way this past August. To my great surprise, it fired right up and is accurate to within a few mV compared to the Fluke 8845A at work. Other than a slightly dim digit it seems pretty healthy. The prettier one on top was bought non working for parts on the 'bay, my intent being if I can't fix it to swap enclosure parts with the working one to make it look less like it's been through the war.
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-VHtGB9g/0/L/IMG_8711-L.jpg)
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-XbXCPfJ/0/L/IMG_2079-L.jpg)
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-wtS63ZR/0/L/IMG_2086-L.jpg)
The 3456 is another eBuy parts/not working unit I got for a song; haven't yet dug into it to asses its condition yet. The frequency counter beneath it is another fix-it project; I think there's something amiss in the front end.
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-rFmWgn7/0/L/IMG_8712-L.jpg)
This pair of 3440As also came from Apex; according to their property tag stickers they were delivered to Bendix 50 years ago in August - both have asset stickers on the back dated 8/65. I'm assuming that the caps are dried out. The display on one counts randomly; alas the second will likely end up a parts mule as it's missing a couple of circuit boards, so I haven't powered it up or swapped boards about at this point.
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-xNtmRF4/0/L/IMG_8713-L.jpg)
And last but not least, another purchase from the auction site. This is the meter I used in high school, one of the labs being to draw the damned thing along with its schematic and make up a bill of materials for it as well, with component sources and prices. It sucked at the time, but little did I know that the knowledge would come in handy 20 years down the road. It of course had a dead, corroded battery in it, so there's some cleaning to be done, but it otherwise works well.
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-9VLXt3P/0/L/IMG_8714-L.jpg)
![](https://pmanning.smugmug.com/Electronics/Misc-test-equipment/i-q7vGCBm/0/L/IMG_8716-L.jpg)
I have some more old HP boat anchors that were recently acquired from an estate, but they're not yet fit for public consumption - they spent ten years in a musty basement.
In case it wasn't evident, I have a thing for nixie displays, and to a slightly lesser extent the little dot-matrix-y LED ones HP used to use.
-Pat
ETA 2 pics of 3490A and work Fluke voltage reading comparisons.
