Author Topic: Show your favorite and most used benchtop PSU  (Read 294572 times)
Offline T4P
  • Country: sg
    • T4P
Re: Show your favorite and most used benchtop PSU
« Reply #75 on: February 18, 2013, 05:00:41 pm »
Hmm, that flat thingy with VFDs, what's that meter? Looks nice
Offline PA4TIM
« Reply #76 on: February 18, 2013, 05:30:06 pm »
Just a photo of a Keithley 2000 display showing the output of the PM and photoshopped in the picture
Offline Jonny
« Reply #77 on: February 22, 2013, 02:03:13 am »
My only supply which doubles as a car battery charger. 3-30V 10A with overload protection. Pretty basic, and the multi-turn pot is cheap, has been cleaned once but got scratchy again in a short amount of time.
Jonny
Offline mzzj
« Reply #78 on: February 22, 2013, 09:41:39 am »
Currently I have 8 of these (this is what I would call total overkill)  :-+
+HP 6633A
+ Delta elektronika 300V 4A
+ old homebrew analog power supply
Offline jancumps
  • New Low
« Reply #79 on: February 22, 2013, 10:37:50 am »
Modified Delta 30V 10A
Ah, the legendary holland power supply brand. Good to see one.
Offline PA4TIM
« Reply #80 on: February 22, 2013, 12:34:11 pm »
Yep, this is the SMPS version, and there support is great. If you have a 30 year old one and have a poblem and mail them for a schematic they send you one. I am active on a Duch foum and as soon as someone has a problem with a Delta ( very rare) the guys from Delta support log in and answer the questions them selves.
I love those HPs, i once almost bought one but one of the the problems was it had no banana terminals or other connections on the front.
Fred
Offline mzzj
« Reply #81 on: February 22, 2013, 04:46:16 pm »
Fred
Pretty easy to install by yourself. Just don't buy them from Agilent, they are bloody expensive as extra option. 6632B-series  have pre-made holes on the front, just stick a hole with a x-acto knife and you are good to go.
I love the 663xB series because of their ability to sink current and act as a DC-load. And did I mention accuracy  :-+
For 120 euros they are absolute bargain in terms of accuracy and features.
Offline BravoVTopic starter
  • +++ ATH1
« Reply #82 on: February 22, 2013, 05:09:50 pm »
Fred
Confirmed, I've been stalking this series for quite sometime too, and most people like Fred, don't like it because there are no front terminals, but it can be modded.  ;)
Check this Japanese page, the photos should be self explanatory -> http://blogs.yahoo.co.jp/ngydx785/13391785.html!
Edit : Check out this thread -> https://www.eevblog.com/forum/buysellwanted/hp-6632b-power-supply-electronic-load-in-uk/ , they've been buying like crazy there, two left / 25 sold. ;)
« Last Edit: February 22, 2013, 05:21:51 pm by BravoV »
Offline blackdog
  • Please stop pushing bullshit...
« Reply #83 on: February 22, 2013, 05:41:48 pm »
This is the power supply i use most.
I designed en build this one last year and put it in one of the Cisco PIX 501 Firewall boxes.
Most of the electronic stuff i design is low power and the 30mA en 200mA
currend range is more than enough for most circuits i am testing.
And yes its stable, is uses a Apex VRE310a reference.
Take a peek @ the schematic
Regarts,
Blackdog
Necessity is not an established fact, but an interpretation.
Offline Zapro
  • Breaking stuff to go fix it again
« Reply #84 on: February 22, 2013, 08:08:20 pm »
Well i guess i'll have to show my PSU too. I have two PSU's and some variacs. The small PSU is just a cheapie like this http://goo.gl/KoPVj
Anyway, the "real" PSU is a Delta Elektronika SM7020 - 0-70V 20A  :bullshit:
I've tried to build some Nixie-based Voltmeter/Ammeter for the PSU, but never got it finished...
HOW to make pictures fullsize? i cannot find the button that does that.... It only shows the thumbnails...
« Last Edit: February 24, 2013, 06:20:12 pm by Zapro »
Offline Circuitous
    • Corgi-Tronics
« Reply #85 on: March 02, 2013, 02:13:58 am »
Of these, I probably use the DP1308A (lower left) the most:
I just got this one yesterday, TTi QPX1200SP  1200Watts:
Offline c4757p
  • adieu
« Reply #86 on: March 02, 2013, 02:28:19 am »
Oldies but goodies.
  • +++ ATH1
« Reply #87 on: March 02, 2013, 04:53:14 am »
Oldies but goodies.
Assuming the mechanical parts are properly cleaned & lubed and also consumable parts like caps are refreshed with good ones. When every time I saw this particular psus, had a feeling that these oldies life might be longer than ours.  :-\
Offline c4757p
  • adieu
« Reply #88 on: March 02, 2013, 05:09:02 am »
Neither one is dated, but the parts inside are - the one on the left was made ca. 1964! Interesting to see how it was designed. The circuit board is FR4-style material, but with no traces - everything is wired point-to-point on turrets. Despite that, the layout is impressively clean and could pass for a modern PCB layout. Surprisingly few transistors for an all-transistor design (no ICs in this one, thank you very much!) with its specs. For some reason, they felt they needed rails near 100VDC for a power supply with a maximum output voltage of 20V... I guess efficiency hadn't been invented yet  ::) They used such high quality parts that even all the capacitors are still in perfectly good shape. I did have to "adjust" a couple of the precision resistors in the divider, though.
Offline robrenz
  • Real Machinist, Wannabe EE
« Reply #89 on: March 02, 2013, 06:28:12 am »
What techniques are you using to adjust the divider resistors?
Offline c4757p
  • adieu
« Reply #90 on: March 02, 2013, 02:40:50 pm »
In one case, adding a tiny (0.5) series resistance, and in the other, a huge (22M) parallel. That way the bulk of the resistance still comes from the probably very stable resistors that are already there.
Offline robrenz
« Reply #91 on: March 02, 2013, 03:05:53 pm »
To not derail this thread, could we discuss this further in my questions to you here  POWER DESIGNS PRECISION POWER SUPPLIES ?
Offline ecat
« Reply #92 on: March 06, 2013, 10:54:29 pm »
Arrived today from ebay, Systron-Donner PQ20-2.
Here I have a couple of 10r resisters on the rear connectors.
The Bad:
Absolutely zero information about this or most other Systron-Donner equipment on the internet so, if it doesn't work you are in trouble.
The Good:
Absolutely zero information about this on the internet so, not very popular and therefore cheap, very cheap £17 excluding shipping.
Not had much time to play with it yet.
The two units can be separated from the rack making for a smaller setup.
The voltage can be controlled by an external 0-10V source - maybe the current too.
The current limit works as a CC source just as one would expect.
The on/off switch is on/off so no way of presetting current but...
Those pots on the front are 10 turn so I could fit a couple of counting/vernier type dials, I have a couple lying around.
A quick look inside reveals what appear to be six silver-mica caps per unit. Now, I know very little about electronics, but I do know you don't scatter silver-micas around just looks, they are not cheap.
All in all, quite a cute little bugger :)
« Last Edit: March 07, 2013, 11:04:15 am by ecat »
Offline talsit
  • Country: jp
    • naniBox
« Reply #93 on: March 11, 2013, 05:19:16 am »
This one is mine!
It's a Kikusui PAN35-5A, I bought it 2nd hand just 4 days ago, and I'm already liking it quite a lot. It does have a serious problem though - the fan is incredibly loud!
I haven't seen anyone else with a Kikusui, is it not available outside Japan?
// dmo @ nanibox
Offline RickieSalad
« Reply #94 on: March 11, 2013, 06:33:40 am »
Mastech HY3005F-3
  • +++ ATH1
« Reply #95 on: March 11, 2013, 07:40:35 pm »
Finally ... a Japanese psu, looks like my Kenwood has a Japanese friend now in this thread ! ;D
Yep, Japanese's stuffs is rarely discussed here in this forum.  :'(
Offline talsit
  • Country: jp
    • naniBox
« Reply #96 on: March 12, 2013, 08:13:41 am »
Yeah, I was looking at the Kenwoods, but the only 2nd hand ones they had were 18V ones, and I needed 32V ideally. The Kikusui ones were quite pricier, and a lot more than I wanted to spend, but it was either this one, or a really crappy one rated only at 110V 60Hz (and in Osaka it's 100V 60Hz), and they had warning stickers saying that the full DC range won't work, only to 10%...
// dmo @ nanibox
  • +++ ATH1
« Reply #97 on: March 12, 2013, 09:41:12 am »
Hey Talsit, how much those 2nd hand used psu cost there ? Like your or Kenwoord, just ballpark number/approx. in US$ currency equivalent ?
Really curious at the Japanese market price there, especially for used ones, how bout others instruments like scope, dmm and etc ?
Btw, I'm assuming you're native Japanese, is it possible asking your help to find the Kenwood psu "service manual" like mine at the 1st post at maybe Japanese forums or mail-list ? I got the user manual already, opened it once and noticed its still using thru hole components, I guess its easy to repair, pretty please if its not troubling you too much.  :)
Fyi, all Kenwood's lab psus series is now owned by a company called Texio.
PS : Always felt dizy when reading google translation from Japanese -> English.  :-[
« Last Edit: March 12, 2013, 09:50:11 am by BravoV »
Offline maca_404
« Reply #98 on: March 12, 2013, 09:59:30 am »
Talsit did you look at replacing the fan,  I had the same issue with a lipo charger I have and replaced the fan with a more quality unit and its quiet as a mouse now.
Offline talsit
  • Country: jp
    • naniBox
« Reply #99 on: March 12, 2013, 10:22:49 am »
Mine cost me 31500 yen (http://www.xe.com/currencyconverter/convert/?Amount=31500&From=JPY&To=USD). It's in really good condition, they had 3 from the same lab, all looked like they had been used, but taken very good care off. They also had 3 others, from a different lab, but these were older, and looked like they were put on a trolley (and sometimes, they may have fallen off a trolley!). I'm quite happy with it.
This is where I bought it from: http://techno.kyohritsu.com/keisokuki/index.html
They haven't updated that page for a while, but those are the basic prices.
Well... you assume wrong! I just got here 2 months ago, with very very VERY little japanese skills. So it has been an interesting experience so far. But yes, I can't really help you search for that unless it's through google translate!!
// dmo @ nanibox
