While doing minor cleaning & housekeeping on my bench table, when I was arranging things & moving stuffs around, was a bit struggled when I lifted my favorite and mostly used bench psu which it's weight about 14 Kg / 31 lbs
![Phew :phew:](https://www.eevblog.com/forum/Smileys/default/phew.gif)
, then suddenly remembered that this forum has no bench psu thread like the popular one "Show your Multimeter!" thread, took snapshots and here we are.
If you have more than one or too many like Dave does
![Evil >:D](https://www.eevblog.com/forum/Smileys/default/evil.gif)
, just post one or two that you "mostly used" when you're tinkering with electronic projects/circuits. Presumably its is adjustable type, and diy type is also welcome.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
Please, post & share the photo of yours, and your own comment about it as well.
Let me start mine, a 36 volt 10 Amps Japanese linear bench psu Kenwood PD36-10AD (
Link), probably made around late 80s or early 90s.
Like :
- The auto emergency shutdown feature (crowbar ?), if the voltage rail crossed the adjustable OVP limit, the power switch will snap mechanically to off position instantly.
- Very low over shoot in CC mode when turning ON the output, it won't toast a led like the example attached photo below, really love this particular feature. Remember, this is a 10 Amps capable beast.
Dislike :
- Its so damn heavy and did I say its expensive ?
![Cry :'(](https://www.eevblog.com/forum/Smileys/default/cry.gif)
... looking at the back of my shoulder just in case wifey is peeking
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
- Although its working perfectly fine, but still feeling uncomfortable cause there is no service manual available like those cool & great HP (Agilent) bench PSU series.
![ThumbsDown :--](https://www.eevblog.com/forum/Smileys/default/icon_thumbsdown.gif)
Front & rear shots, the rear has all those terminals for many features like parallel/series connection, remote sensing, external reference (volt or resistance) for voltage and current loop, remote output on/off and etc.
Now, your turn.
PS : Please, resize the photo like 1024 or max 1280 pixels wide, not the raw huuuge sized photo directly from your camera. Also its highly recommended to use the attachment feature to embed photo in your own post like I did here, rather than using external hosting, why ? A nasty example on the 1st post, image at external hosting simply sucks -> HERE
The attach picture feature is right below the dialog box where you type your post.
