TI OPA891 datasheet: "These amplifiers are built using a 36V, complementary bipolar process with NPN and PNP transistors that possess an f
T of several GHz."
You can sort by I
B at Digi-Key, it appears speed is not a factor though. Bias-cancellation is there or not I guess.
Previous TI datasheet rev had an "oops nA not uA" edit lol thought slim chance it might apply.
I was pitting the part against an
LT1115 plus
LT1010 buffer, as in Walt Jung's excellent solutions in the LT1115 datasheet. I
B 50nA typ. (at room temp) so the bias cancellation circuit is there. Same value for
LT1028/1128.
