Author Topic: Sharing some electric shock experiences  (Read 3021 times)
Offline Infraviolet
Re: Sharing some electric shock experiences
« Reply #25 on: August 05, 2024, 10:56:11 pm »
I was in my teens when I got my biggest one, a 400V DC one, from a camera flash capacitor. I knew there was high voltage in there, the remains of a disposable camera, and wanted to get it out and see if I could make tiny arcs with it, but hadn't given the cap time to discharge before I got out the pointy screwdriver to pry open the casing. The thing that gave me the real surprise was that I got the shock while holding the camera's PCB from the sides (must have been copper right to the edges escaping from under soldermask), rather than just the obvious metallic soldered bits which I thought, at the time, to be the only conductors that the cap would be able to energise. Paralysed a whole arm for about a second, then there were quite a few minutes to hours with the hand and forearm feeeling somewhat unnatural.
It seems capacitors are the pretty common theme on this thread, including being shocked by them even when you knew they were there. after my shock I learnt enough to tear down disposable cameras and get the high voltage bit I wanted whilst knowing how to get rid of the big electrolytic before bringing the hands anywhere near it, so I could get the high voltage I wanted to try things with but at the low current I knew couldn't be too nasty. Less memorable, more amusing, shocks followed, some entirely deliberately self inflicted, once I had 400V dc at negligible current directly from the camera circuits' step-up transformer output.
Also: this might be controversial, but a little bit of a dictionary definitions argument comes up here. I didn't follow the link to the article, but the 11KV shock in wolverhampton, well if the man was "electrocuted" how does he then go on to give a past-tense quote about his experience. I had always worked under the definition that if anybody, however severely injured, can ever report about what it was like, it was an electric shock (or electrical burn...). To call something an electrocution, is it not the case that the person undergoing it, by definition, does not live to tell the tale?
« Last Edit: August 05, 2024, 11:27:19 pm by Infraviolet »
Offline IanB
« Reply #26 on: August 06, 2024, 02:33:33 pm »
If you follow the link to the BBC news article, you find that it was the BBC journalist who made this mistake. You can't even trust the BBC to have good editors these days.
Online themadhippy
« Reply #27 on: August 06, 2024, 04:05:58 pm »
That was also my understanding,but the goalpost have moved and the definition of  electrocution is  now death or sever injury from electric shock
Offline EPAIII
« Reply #28 on: Yesterday at 06:43:03 am »
Mothers need to be made of stout stuff.
My one (and only) electric shock happened when I was three years old and stuck a butter knife into an electric outlet. I guess I learned my lesson.
That was my age at introduction to electricity via a shock too.  My mom threw away a bad extension cord.  I dug it out of the trash and plugged it in.  The frayed end was the plug...   She said she heard a big bang, ran into the kitchen to find me sitting on the floor with a shocked look [pun intended] on my face, my hand blackened and a cloud of smoke rising in the air.  Probably, I think, I mostly got a slight burn from the arc.  But she said I was hooked on all things electric after that.  So I credit my entire career and hobbies to that shock.
Paul A.  -   SE Texas
And if you look REAL close at an analog signal,
You will find that it has discrete steps.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #29 on: Yesterday at 09:16:19 am »
I've had my share over the years, nothing too serious luckily. One near miss - I once replaced all the caps on the secondary side of a SMPSU and then realised it had been powered on the  whole time!
Day Job: Mostly LEDs
