Author Topic: scientific calculator with engineering notation keys  (Read 14898 times)
Offline RoadRunnerTopic starter
« on: October 04, 2016, 07:52:05 am »
I am looking for good large display(graphical is preference) , scientific calculator with dedicated (or even with press of shift like in casio fx-991ms) keys.
i know it can be done using exponent key. I just love have dedicated keys.
every suggestion will be helpful.
Offline rstofer
Re: scientific calculator with engineering notation keys
« Reply #1 on: October 04, 2016, 01:34:55 pm »
Are you talking about a dedicated key to enter the exponent like the HP48-GX 'EEX' key?
Offline 2N3055
  • Country: hr
« Reply #2 on: October 04, 2016, 02:28:06 pm »
No he means like this to have dedicated units buttons with shift like on this Casio .. mega, kilo, nano, pico...
It is useful ...
Offline rstofer
« Reply #3 on: October 04, 2016, 03:14:35 pm »
Got it!
That would be a pretty nice feature for engineering students.  I sure haven't run across it.
« Reply #4 on: October 04, 2016, 05:57:38 pm »
the only new calculator which i see has this feature is ,casio fx-991ms.
don't know why they dropped it on new models .
Offline mathsquid
  • I like math.
« Reply #5 on: October 04, 2016, 08:47:21 pm »
The casio fx-9750GII does engineering prefixes.  It doesn't have dedicated buttons, but the function keys below the screen can do it.
The following users thanked this post: RoadRunner
Offline kulky64
  • Country: sk
« Reply #6 on: October 04, 2016, 09:04:28 pm »
I have fx-991MS and as far as i remember I never used this function. It takes two button presses to insert your prefix, same as pressing "EXP" button and some number.
« Reply #7 on: October 06, 2016, 06:53:14 am »
 ;D this seems to be really nice calc. i think i found what i was looking for.
Offline AndyC_772
« Reply #8 on: October 06, 2016, 07:12:27 am »
The FX-115MS Plus has engineering units too.
It's never been a common feature and I don't know why either. Perhaps by far and away the biggest market for scientific calculators is for academic use, where engineering units just aren't used that frequently?
Offline setq
« Reply #9 on: October 06, 2016, 07:24:01 am »
Japanese still use calculators for a lot of things so always look in that direction.
« Reply #10 on: October 06, 2016, 07:43:47 am »
you are right , sci calc are more of academic thing, because i have been using this feature since i was in college , i just seems to like it.
Offline David Hess
  • DavidH
« Reply #11 on: October 06, 2016, 04:47:40 pm »
While they do not support the general use of the SI prefixes, one feature I have always liked in the HP48 and HP50 is that they support engineering notation where the power of 10 exponents are displayed in multiples of 3.
Offline setq
« Reply #12 on: October 06, 2016, 05:27:40 pm »
50g is nice. It supports full SI unit notation and units are typed so you can enter "12_m" "1000_pm" / and it'll work out and factor the units.
Problem is that you end up in a unit hole occasionally where you end up with 1 square decameter amp volt to the power 2 and wondering where the hell that came from!
Actually I suddenly wish I hadn't sold mine.
Offline SteveyG
  • Soldering Equipment Guru
« Reply #13 on: October 06, 2016, 06:18:38 pm »
I'm a big fan of the fx-991MS. I permanently have it in ENG mode, so results are always printed on the screen with actual engineering units from any calculation and the two button press for input is so fast.
My old Casio CFX-9850G had either 2 or 3 button input, but I don't remember it being able to display engineering units as the result by default, it'd use scientific notation but fixed at x10^-3, -6, -9, -12 etc.
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline SteveyG
« Reply #14 on: October 06, 2016, 06:25:30 pm »
The nice feature is you can permanently set it to output engineering units too!
Offline rstofer
« Reply #15 on: October 06, 2016, 06:33:38 pm »
That is a very handy feature.  It's been decades since I seriously used FORTRAN and I discovered the other day that that feature has been added to FORMAT statements.  Very nice!
My HP 48GX will remain my favorite calculator despite owning an HP Prime and a TI NSpire.  Sure, the graphics are better on the NSpire and the Analyze Graph feature is magnificent but I am just plain FAST on the HP48 GX.
Offline Berni
  • Country: si
« Reply #16 on: October 06, 2016, 08:45:40 pm »
That would be pretty neat to have but as long as there is what they call "engineering notation" where the power of 10 exponents go in multiples of 3 i am fine with it.
I still use a basic TI 30X calculator. Gets the job done for everyday calculations. In uni i used to use a TI nspire, pretty impressive the stuff it can do but it takes forever to get anything done on it. Just waiting for the thing to boot takes a long time, later on that clumsy keyboard doesn't do any favors to speed. But when needing to solve the more fancy pants math you come across in school it helped a ton solving big convoluted systems of equations, working with matixes, complex number math etc. But in my day to day job it rarely goes beyond ohms law.
Offline David Hess
  • DavidH
« Reply #17 on: October 06, 2016, 10:10:24 pm »
But it does not support general use of the SI prefixes like Gaurav originally asked about.  The factor-label/dimensional-analysis notation works well enough but I find that it usually gets in the way so I only use it for conversions.
I would not mind being able to use SI prefixes in addition to engineering notation but I did some searching and apparently there is no way to add this to the HP48/HP50.  Just the other day I was using femtoamps and attoamps and this would have been handy.
The HP50G is a worthy replacement for the HP48 with a lot of improvements.  My only complaint about it is that despite having 40 times the processor performance, it has much greater maximum key-press latency.
Online EEVblog
« Reply #18 on: October 06, 2016, 10:32:55 pm »
FX-61F
It even has a parallel button!
Offline setq
« Reply #19 on: October 07, 2016, 06:31:20 am »
That's pretty neat! I had to write one when I had an HP50g :)
« Reply #20 on: October 07, 2016, 06:38:29 am »
FX-61F
i would love to have calc like this , too bad they don't make calc for electronics use any more.
« Last Edit: October 07, 2016, 11:43:11 am by Gaurav »
Offline 2N3055
  • Country: hr
« Reply #21 on: October 07, 2016, 08:23:05 am »
FX-61F
It's in a good shape, like mine, I also have original etui for it.. First owner, it's been more than 25 years I guess... Still remember my professor's face when he saw it first time.. he let me use it after  he tried it, big smile on his face... he just asked where did I get it from .. ^-^
Offline Berni
  • Country: si
« Reply #22 on: October 07, 2016, 08:31:41 am »
Yeah id buy one if i could find it.
Anyone here looking for a kickstarter idea?
Offline 2N3055
  • Country: hr
« Reply #23 on: October 07, 2016, 08:49:38 am »
I'w been thinking about it for some time.. For me it even wouldn't have to be so thin and light.. Just to have same functionality...
Online EEVblog
« Reply #24 on: October 07, 2016, 01:28:58 pm »
I've always thought about it...
