Author Topic: Magnetic lines of the Earth - magnetic dip angle bigger than naively expected  (Read 2483 times)
Online RoGeorgeTopic starter
« Last Edit: January 05, 2019, 10:55:39 pm by RoGeorge »
Online CatalinaWOW
Re: Magnetic field lines of the Earth are mostly pointing downwords
« Reply #1 on: January 05, 2019, 04:19:28 pm »
Didn't watch the video, but anyone who paid attention in a good physics class would know that the field of the earth is 3D, and is only parallel to the earths surface near the equator.
Image using a compass in Newfoundland or in Alaska.   Both far north with strong vertical components.  And very different results due to the details of earths magnetic field.
« Reply #2 on: January 05, 2019, 05:11:39 pm »
The surprise was that the angle is much bigger than I was expecting, because the magnetic core is much smaller than the whole Earth.  Also the tilt distribution is far from being uniform:
Offline GeoffreyF
« Reply #3 on: January 05, 2019, 05:17:58 pm »
It's only a surprise because you formed an expectation without bothering to read the subject.  Your post is still pointlessly lacking in any effort at education.  I also suggest that you read up on how distortions occur with different types of map projection.
US Amateur Extra W1GCF.
Re: Magnetic field lines of the Earth are mostly pointing downwards
« Reply #4 on: January 05, 2019, 05:46:47 pm »
Well, it seems that magnetic lines tilted downward up to 30 degrees at the Equator is common knowledge for everyone but me.   ;D
« Last Edit: January 05, 2019, 05:50:33 pm by RoGeorge »
Offline chickenHeadKnob
« Reply #5 on: January 05, 2019, 06:14:37 pm »
Understanding magnetic deviation+variation is basic component to all pilot training and quite evident, especially if you are a bush pilot in Canda's north or Alaska.
Offline Gyro
« Reply #6 on: January 05, 2019, 06:27:09 pm »
This seems like a perfect opportunity for whoever it is around here, who has is location set to Antarctica, to pitch in a demo.  ;D
Best Regards, Chris
Offline raptor1956
« Reply #7 on: January 05, 2019, 06:41:20 pm »
Correct me if I'm wrong, but wouldn't there need to be a pretty much equal number of lines exiting the Earth as there is entering the Earth.  The magnetic poles are not coincident with the axis of rotation which complicates things a bit and the makeup of the Earth is not consistent with variations in the distribution of iron and other ferromagnetic materials.
Brian
Offline duak
« Reply #8 on: January 05, 2019, 07:24:25 pm »
Fun fact: it's called magnetic inclination or dip: https://en.wikipedia.org/wiki/Magnetic_dip
More than you might want to read about the field:  https://en.wikipedia.org/wiki/Earth%27s_magnetic_field
In a book on the Hubble Space Telescope there was a reference to the South Atlantic Anomaly where it's computer would crash & then go into safe mode:  https://en.wikipedia.org/wiki/South_Atlantic_Anomaly
The following users thanked this post: RoGeorge, BrianHG
Thank you. Title changed to include the proper term:  magnetic dip.
Offline cs.dk
« Reply #10 on: January 05, 2019, 08:49:47 pm »
 :-DD :-DD :-+
Online CatalinaWOW
« Reply #11 on: January 05, 2019, 09:38:17 pm »
Given the accelerating rate and direction of motion of the magnetic north pole there could be a new thread started:
"The Russians are stealing the North Pole"
