Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
General
General Technical Chat
Board House that does THIN boards?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Board House that does THIN boards? (Read 3272 times)
Veramacor
Regular Contributor
on:
March 19, 2010, 12:46:33 am »
Anyone know of a board house that accepts PCB boards < .5" in width? (not thickness, .062 FR4 is cool)
I'm looking at making a sensor that can fit in some pretty small diameter tubing.
The sensor IC is SIO8 so its well under half an inch. PCB wing for example has a minimum with of 20mm or .78"
I'm looking at maybe around .25" width...
J
Last Edit: March 19, 2010, 11:46:56 am by Veramacor
Logged
DJPhil
Frequent Contributor
Country:
Re: Board House that does THIN boards?
Reply #1 on:
March 19, 2010, 04:09:20 am »
This may not be helping any, but could you lay out two or more on one large board?
When you get your board you can score and snap the edges or use a paper cutter, and you'll have several boards to work with.
Logged
desolatordan
Regular Contributor
Country:
Reply #2 on:
March 19, 2010, 05:08:29 am »
Best to cut it down yourself as DJPhil suggests. Or you can panelize your boards and get vscoring or tab routing, but it will be more expensive.
BatchPCB allows 0.5" width, not sure if that's small enough for ya.
Logged
mkissin
Regular Contributor
Reply #3 on:
March 19, 2010, 05:11:00 am »
I think you'll find that the limits they post are for sales reasons, not technical process limits.
If you wanted a bunch of these boards, they should be able to panelise them for you and make really thin ones. Try sending them an email and asking.
Logged
GeekGirl
Guest
Reply #4 on:
March 19, 2010, 07:31:14 am »
The reason for a minimum size is mechanical stress and tooling.
Most places can do smallish boards, they can panalise in large boards and V score or route the pcb.
This will make it more expensive.
Logged
Veramacor
Regular Contributor
Reply #5 on:
March 19, 2010, 11:52:35 am »
The V-scoring on a larger panelized board sounds like the way to go.
I think I'll go that... 'route', uh huh huh...
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
General
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
