Thanks for the info, I wasn't aware of the parasitic capacitance. Most sources I've seen (eg.
this and
this, just random datasheets) seem to consider them superior to metal film for high frequency (thin film is obviously superior). The first datasheet recommends carbon composition for a part that has transition times of 20-30ns, not exactly GHz speed, but no 10MHz either.
I find it suspicious that the graph has only one curve for carbon composition, I can't imagine parasitic capacitance having the same influence at say 1ohm and 1Mohm. I also doubt that all carbon composition resistors are useless beyond 10MHz, lots of equipment from the seventies and earlier was full of carbon composition (wirewound was inductive, and metal film expensive), many of it can go beyond 10MHz. I'd have to check if for example the Tek TM500 series (which uses lots of carbon composition and multiple plugins go up to 250MHz) use metal film in all places that need to pass high frequency. I believe carbon comp was frequently used as termination resistor, but if they'd only work up to <10MHz, they'd be almost useless, since you need fairly long cables to even notice the transmission line effect at that frequency.
I just checked, the Tek PG-502 (250MHz pulse generator with a rise time of <1ns) uses two ~50ohm carbon composition resistors (as indicated in the electrical parts list) as switchable rear termination, with no reactive components nearby to compensate for parasitics. It would need about 350MHz bandwidth to reproduce the 1ns edge, can't imagine that the termination has a zero impedance (extrapolating from the graph you posted) at those frequencies. These were just the first resistors I checked, there are many more carbon composition resistors in there (and in similar equipment of that vintage). There are some 1% metal film resistors, but they're there because of accuracy/stability. This doesn't mean that carbon comp is superior to metal film for HF, but it does suggest that carbon comp works well beyond 10MHz.
Maybe there are different ways of producing a carbon composition resistor? That would explain the conflicting data, although I've never seen something like a 'low-capacitance carbon comp resistor'.
