I concur with mecha, but to simplify it, for square waves, for a nice clean sharp edge, I've got at
least 10 MHz, and with sinusoids at
least to 70 MHz, and useful up to its limit of 100 MHz. This is the limit of what I can see myself, using my scope, not that its truly the limit of the 3x25. I start to see edge roll off at about 20 MHz, where the harmonics are over 100 MHz, beyond my unmodded Rigol 1052e capabilities.
Compare to what you get with other function generators of 20 MHz, such as the Rigol 1022 at $400+, and you see you get a good bang from the lowly 3x25.
The cleanest waveforms for all types are in definitely in the 10 MHz and lower region.
So it gives good high frequency for general purpose use well matched to a home lab scope.
oh. If the problem is during transition only I can't see it affecting me that much at this point. At least I hope not
One question, what's the maximum frequency of all waveforms with the latest modifications you have posted?
