Author Topic: Can you ID these (Fluke?) test probes?  (Read 3010 times)
Offline iconTopic starter
« on: May 04, 2012, 11:39:13 am »
Hi
I just acquired a Fluke 87v second-hand but new (boxed, manual still shrink-wrapped, all paperwork, CD, etc) in the UK. It came with a sealed bag containing a Fluke-branded thermocouple and the probes/clips in the pictures below. The probes have a sprung-loaded retracting shroud, and they unscrew to reveal a 500mA fuse. You can replace the probe with a gnarly-looking alligator clip, or you can slide a (Fluke-branded) small alligator clip over the probe. The probes themselves have no model number/branding.
My question is - what model number are these probes? I asked Fluke UK what probes were being shipped with 87v/EUR meters, and they couldn't give me a sensible answer. I'm planning on selling them - they're as much use to me as a crowbar for mending watches - but I'd like to give them a proper name.
Cheers
John
Offline G7PSK
  • It is hot until proved not.
Re: Can you ID these (Fluke?) test probes?
« Reply #1 on: May 04, 2012, 05:21:33 pm »
I don't know what the model number of those test leads are but the look very useful to me.
Offline chrome
« Reply #2 on: May 04, 2012, 06:46:59 pm »
I think only the shrouded alligator clip is from fluke, the rest doesn't seem to have the right color and general quality that fluke uses.
Offline ModemHead
  • No user-serviceable parts inside.
    • Mr. ModemHead
« Reply #3 on: May 04, 2012, 07:02:05 pm »
Looks like TLK291 fused probes.  Never actually seen those before.  Grainger says country of origin is China. That may explain the "look."  The small clips are regular old AC72.
« Reply #4 on: May 04, 2012, 09:23:52 pm »
Yes! They look very similar to mine, except mine are on a regular lead with a conventional 90deg shrouded 4mm plug. Thanks.
John
Offline ModemHead
    • Mr. ModemHead
« Reply #5 on: May 04, 2012, 09:57:54 pm »
Interesting design. I've only seen the big fat fused probes before. FTPL or something like that.
Does the shroud around the tip slide back somehow?
« Reply #6 on: May 04, 2012, 10:40:57 pm »
Yes, they're sprung-loaded and just telescope back into the body of the probe.
John
« Reply #7 on: May 05, 2012, 05:24:58 pm »
Having had a poke around on the Internet, it seems the UK has this guidance http://www.hse.gov.uk/pubns/priced/gs38.pdf which recommends the use of probes of this type, which presumably explains Fluke substituting them in this country.
John
