With a HT of 120V from a B+ battery any cap above 160V will work for supply decoupling. Myself I would increase the value to 100n 250V polyester, unless it is a screen grid, where I would use the original value but rated for 3 times the battery voltage as the screen can be driven to double the supply in a push pull amplifier with output transformer. You can use a 4n7 630V unit there.
