Hi, bit of a shot in the dark here.
I have an old (1980's) military radio set, it has some nice proper mil-spec connectors and cables on it already. I need to make up a new control cable for it though. I don't want to spoil it by fitting a cheap RS-232 cable, it would work, but would be a bit out of place.
So where do I find decent mil-spec multicore cable ? the cable's that are on it already are quite thick, but really very tough and yet very flexible.
The connector is Amphenol 62LC-16F10-06SN-(771)
https://uk.rs-online.com/web/p/industrial-circular-connectors/3014478/I'll spare you the trouble of deciphering the datasheet
62LC-16F = Shell style
10-06 = Layout (6 pin, size 20)
S = Contact (socket)
N = Keyway
771 = Modifier (Black Zinc Cobalt)
So wire size options for this connector are 20, 22, 24 AWG
I need it to be shielded, and I think, given the connector type, having a drain will make it easier to connect up
