Author Topic: Need for Custom Electronic Enclosure Inquiry  (Read 1450 times)
Offline willysnowmanTopic starter
« on: August 06, 2014, 08:38:21 pm »
Hi All,
I am a Mechanical Engineer with several years of electronic packaging. I have been getting a lot of jobs lately to wrap an enclosure around an ECAD file. These jobs consist of 3D printed, machined, and sheet metal enclosures.
I have set myself to accommodate these needs at a prototype level. I can do quick turn on iterations. I typically take a product through to production, but I am thinking of just specializing on the prototype design iterations. I think it will be good for the customer shorten the cycle time. It will be good for me since I will not have a lull between jobs (as is now).
The idea behind it is for the customer to send an ECAD file. We design an enclosure based on your needs or specifications. We can do fit and function (EMI, thermal, shock, water/dust ingress). I have someone who can do industrial design if you need a certain form.
Would you be interested in a service such as this? I have attached a flow chart to give you an idea on how this would work.
Thanks in advance for feedback.
Bill
