« Reply #4 on: September 28, 2017, 11:34:17 pm »
I had my first bit of learning on auto ECM.
Fuel Injectors Voltage and Current.
Cylinder compression, I built my own pressure transducers.
Fuel Pressure gauges.
1000:1 Spark probes
You need a good current probe. For battery, Fuel pump, Fuel injectors.
I bought the Snap-On.
Bought a Rigol 50 megahertz scope 1052 I think could set it under the hood without many problems.
It did everything that was needed. But was a bit inconvenient really not meant for under the hood environment.
After a while I purchased a Snap-On Verus Wireless at auction.
I want to pick up a Fluke 199C for the future use.
Believe they are more robust than most.
Something you want to be aware of.
Brightness of display is of utmost importance.
« Last Edit: September 29, 2017, 01:48:35 am by Johnny10 »
![](https://www.eevblog.com/forum/Themes/default/images/ip.gif)
Logged
Tektronix TDS7104, DMM4050, HP 3561A, HP 35665, Tek 2465A, HP8903B, DSA602A, Tek 7854, 7834, HP3457A, Tek 575, 576, 577 Curve Tracers, Datron 4000, Datron 4000A, DOS4EVER uTracer, HP5335A, EIP534B 20GHz Frequency Counter, TrueTime Rubidium, Sencore LC102, Tek TG506, TG501, SG503, HP 8568B
