Dear Psi:
--Thank you! Exactly what I need. The AsRock 970 Pro3 R2.0 even has 6 SATA disk slots. I am ordering one. I may even get 2. I often run 4 disks so I use only large cases with at least 4 5.5 Front Panel slots and as much and many fans as possible, All disks in hot swap racks with fans. Minimum600 W PS. I do all of this because I have destroyed a number of MBs, PSs, HDs and SSDs, all due to continuous use where the disks exceed 42C. I am not a gamer, but I do tend to beat disks, MBs, and PSs to death, but Hard Disk Sentinel has taught me the error of my ways. Thanks again for you super speedy help.
“For neither good nor evil can last for ever; and so it follows that as evil has lasted a long time, good must now be close at hand.” from Don Quixote
Miguel de Cervantes Saavedra 1547 - 1616
Best Regards
Clear Ether
