When designing this amplifier the goal was clear, maximum power in the minimum amount of space. With 300 watts squeezed into the smallest of enclosures, this amp truly has to be heard to believed, so if you're short on space but don't want to sacrifice on sound, this is for you!
High and lowpass filters allow precise control over your sound. With robust housing and well engineered internal components, all in a brilliant compact design, this little gem wont let you down!
Highlights:
300W max. output - equivalent to 2 x 30W RMS
Adjustable high and low-pass filter
Polished silver metal case
Features:
Connections: RCA input, high input
Gold plated RCA connectors
Low Pass Filter: 40 to 250 Hz
High Pass Filter: 80 Hz to 2 kHz
Frequency response: 40 Hz to 20 kHz
Input impedance: 40 kOhm
Distortion factor: > 0.1%
Signal to Noise Ratio: > 79dB
Output impedance: 4 to 16 ohms
Adjustable Volume
[1] How do we correlate the "300W max." and "2 x 30W RMS" power? I thought Max. Power (Pmax) = 2 x Power in RMS (Prms)...
[2] Usually home audio amplifier do not state "low pass filter" or "high pass filter". Why do we need these specs in a car audio amplifier?
[3] Is it good to have a HIGHER or LOWER input impedance? What is the typical input impedance of an audio amplifier?
[4] Does the "Output impedance: 4 to 16 ohms" mean the output impedance of the audio amplifier or the impedance of the connected speaker?
Looking at the rest of the specs, this does not look like a very good amplifier. First of all the power is quite low, comparable with a modern CD player source. The low frequency response is acceptable but dont connect this to a subwoofer.
A random distortion figure is given. I take it it refers to THD+N distortion? Who knows. Anyway it says >0.1% Note the unequality symbol meaning greater than 0.1%! Possibly 0.5% or 1% is what they meant? lol. This is a terrible figure from a modern transistor amplifier.
I would suggest you continue looking for a better amplifier. What system do you have in mind overall?
This could be taken out of context as 'V' changes from amplifier to amplfiier. Take the TDA1562Q operating in class H for example. It uses two switched capacitors to boost its power supply during signal peaks.
Bandwidth is meaningful, for amplfiiers -3dB is the norm, I assumed this is the case here. But who knows seeing how the other specs are inflated.
The specs are improving :-D
But your power supply is intended for a main connection (240V AC)!
You need 10-14 or thereabouts power supply voltage.
I see. What sort of power and peak voltage do you want in your toroidal transformer? Whats connected in the secondary? If this for a step up converter you can tolerate a lot of distortion from your power amplifier.
McHammer's car amplifier provides high performance at a price that won't break the bank!
The pitch-black amplifier provides 3550W for your system on 5 channels, and ensures high quality sound even when being ran at high levels.
The McHammer Mystic 5.1 - Stylish, powerful, and durable.
Highlights:
4 x 350 W and 1 x 440 W RMS power (equivalent to 4 x 675 1 x 850 watts maximum Power)
Powerful, adjustable high and low-pass filter
Deep black steampunk design with white-lit, analog VU meters
Features:
Frequency range: 10 - 40000 Hz ± 1dB
Depth Filter control range: 50 - 250 Hz (6/12dB)
Filter height adjustment range: 60 - 1200 Hz (6/12dB)
Input sensitivity for Front + Rear adjustable separately
Input Sensitivity: 0.2 - 5 V
Signal to noise ratio (S / N):> 100 dB
THD: <0.03%
Remote control over the car radio (on / off)
LED indicator for Power & Thermal fuse
Fuse: 2 x 30 A
Power supply: 12 V - DC
Cutout for short-circuit, over voltage and over temperature
At the touch of a button, McHammer amplifiers leave the competition far behind!
The jet-black Mystic 4.0 fires up your system with 2700W of 4 channel power in excellent sound quality.
As you would expect from a McHammer amp, this unit also impresses with its workmanship, handling and durability.
A car amplifier as it should be - just a little edgier!
Highlights:
4 x 350W / 2x 700W RMS power (equivalent to 4 x 675 / 2 x 1350W max. output)
Powerful, adjustable high and low pass filters (6/12dB)
Jet-black steampunk design with illuminated analogue VU meters.
Features:
Frequency range: 10 - 40.000Hz ± 1dB
Bass range: 50Hz - 250Hz
Treble range: 60Hz - 2kHz
Remote control (on/off) over the car radio
Signal to noise ratio (S / N): >100 dB
THD: <0.03%
Input Sensitivity: 0.2 - 4.5 V
Input sensitivity for front and rear separately adjustable
LED indicator for power and thermal fuses
Safety shutdown prevents short circuiting, power surges or over-heating
Fuse: 2 x 25 A
At the touch of a button, the McHammer amplifier easily leaves the competition in the dust!
The jet-black amplifier fires up your system with 1350W of power (2 channel) and provides top of the line sound quality.
The amplifier not only impresses with its professional sound, but also with its workmanship, handling and durability.
Highlights:
2 x 350 W RMS power (equivalent to 2 x 675 Watt max.)
Powerful, adjustable high-and low-pass filter
Stream jet black punk design with white-lit, analog VU meters
Features:
Connectors: RCA input, RCA output
Remote control (on / off) via the car radio
Low-pass filter 40 - 150 Hz
High-pass filter 60 - 1.2 kHz
Frequency response: 20-22000 Hz
THD <0.3%
Signal to noise ratio (S / N):> 93 dB
Fuse: 1 x 25 A
Found few more as below. What do you think about them? Do you think I can use them for my application as a "variable-frequency variable-amplitude sinusoidal voltage source"? Thanks.
Highlights:
Features:
THD: <0.03%
Fuse: 2 x 30 A
Yeah right, assuming 2*30A fuses in parallel, it's 60A which at 12V is only 720W. All the other specifications are total bollocks, I'm not going to waste my time debunking them.
Got to love car power amplifiers.
1mm, how much power do you require in your transformer and at what primary voltage? Maybe you can get away with a power op-amp? Maybe a few transistors? We have no clue as to what you are trying to do.
