the precision humidity and temperature sensors used in cheap digital hygrometers also have the same efficiency as expensive hygrometers?
I'd suggest one of these: https://pt.aliexpress.com/item/32865734504.html?spm=a2g0o.productlist.0.0.473331a9XoSApp&algo_pvid=b63b661f-7361-4204-85fc-31c30ca18e10&algo_expid=b63b661f-7361-4204-85fc-31c30ca18e10-22&btsid=0be3764515937719199577390e340a&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_They're cheap and work fine.
The cable just means that you can measure the humidity in one place, and put the display in another place.For example, put the sensor in a box, and have the display visible outside the box.There will be no difference in accuracy.
Quote from: steve30 on July 03, 2020, 01:07:30 pmThe cable just means that you can measure the humidity in one place, and put the display in another place.For example, put the sensor in a box, and have the display visible outside the box.There will be no difference in accuracy.digital and needle hygrometer have the same precision?
low cost would you recommend the electronic hygrometer or the needle hygrometer?
