Some people say that the microSD and SD HC card inserted for a long time causes a constant tension at the terminals and with temperature variations this can affect the pressure blades of the SD connector
Can I easily keep a microSD or SD HC card inserted for years in the connector without any problems blades contact?
I am starting to suspect you are talking to a troll.
