Author Topic: Question conector cartridge and microSD contacts electrical  (Read 3440 times)
Offline ataradov
    • Personal site
Re: Question conector cartridge and microSD contacts electrical
« Reply #25 on: June 29, 2020, 10:17:19 pm »
Are you a bot or something? You asked and I have answered many times already.
Alex
The following users thanked this post: tooki, Ysjoelfir
Offline micksmelanieTopic starter
« Reply #26 on: June 30, 2020, 12:48:53 am »
Some people say that the microSD and SD HC card inserted for a long time causes a constant tension at the terminals and with temperature variations this can affect the pressure blades of the SD connector
« Last Edit: June 30, 2020, 12:52:30 am by micksmelanie »
Offline ataradov
    • Personal site
« Reply #27 on: June 30, 2020, 12:53:56 am »
Yes, sure, some people say that. Don't listen to those people, they are wrong or misinformed.
Alex
Offline tooki
« Reply #28 on: June 30, 2020, 04:03:41 am »
Have you ever heard of the spring in a ball-point pen failing, even if the pen was kept with the point out for years? No, because spring metals are made to spring within their normal movement range. Seriously dude, stop worrying about this non-problem.
« Reply #29 on: June 30, 2020, 10:27:55 am »
Can I easily keep a microSD or SD HC card inserted for years in the connector without any problems blades contact?
Offline tooki
« Reply #30 on: June 30, 2020, 03:55:31 pm »
Read the replies above. This has been answered directly multiple times. Don’t ask questions if you’re unwilling to look at the replies.
Offline GlennSprigg
  • Medically retired Tech. Old School / re-learning !
« Reply #31 on: July 01, 2020, 01:22:52 pm »
I am starting to suspect you are talking to a troll. ::)
I'm starting to think so too!! although I politely answered a few other of his questions??
What's that old saying...  "Something's Rotten In Denmark"??  Ahhh... it's from a play...
"Hamlet", by Shakespeare. (No offense intended to the Danes!!  ;D).
Diagonal of 1x1 square = Root-2. Ok.
Diagonal of 1x1x1 cube = Root-3 !!!  Beautiful !!
