OK, I have just purchased a couple of patch cables, 50/125. Let's see if they will work.
The manual of the HBA says only this
SC-style connector that supports non-OFC, multimode fibre optic cabling using 1x9 fibre optic transceiver module.
It's completely unclear if the transceiver uses a LED or a LASER, etc, and there are no other recommendations for the optic cabling.
Anyway I am 100% sure, this engine won't go faster than 10Gbs. It's not required, so OM1 "should" be OK.
