Dave did a tutorial about multimeter specifications, which usually use a similar format. Should be easy to find in the episode list, it was quite an early one. Least significant digit refers to the value on the display. It (usually) consists of multiple digits, one is the most significant, and one is the least significant. Multiply the least significant one by the counts you got from the datasheet and you've got your offset uncertainty.
