Author Topic: Connector help  (Read 2133 times)
Offline McPeteTopic starter
  • Layout Designer, AKA eCAD monkey
Connector help
« on: June 26, 2012, 01:27:15 am »
Hey all,
I've had a bit of a puzzler here at work for a few days, so I'd like to ask you all for some help: I've been working on an FTIR that the users are reporting noise problems with. When I removed the detector and preamp assembly, a rather dodgy bit of soldering caught my eye on a particular connector.
What it was/is is a 3mm(o/d) SMB connector on RG174, going into a 90 degree receptical on the PCB. HOWEVER, it's not one of the standard 0.1, 5-pin jobs that Farnell et-al have... It was a two pin connector, 5mm centre-to-centre, with 0.8mm diameter leads. Unfortunately, I made a bit of a hash of getting it off the board and mangled it quite badly.
I was just hoping that someone out there might have run across a similar connector. If I happen across something similar, I'll post it up.
Cheers,
Peter
Offline Psi
Re: Connector help
« Reply #1 on: June 26, 2012, 01:43:52 am »
We need a picture of it, it's too hard to find stuff from a description alone
Offline free_electron
    • SiliconValleyGarage
Re: Connector help
« Reply #2 on: June 26, 2012, 03:15:31 am »
check pasternack enterprises website.. if they don;t have it it don;t exist :)
Re: Connector help
« Reply #3 on: June 26, 2012, 03:22:19 am »
Hi Psi,
Thanks for the rapid response. Please pardon my utterly terrible model, as I've just started using Sketch-up as of 20 minutes ago for purposes of this very question! Here's a model that shows VERY roughly what I'm on about!
Thankyou again for your help!
EDIT 1:
AH-HA! I just saw it! Third from the left on the front page of this catalog:
http://www.sh-shengzhuo.com/upfile/pdf/NON-MAGNETIC%20CONNECTORS.pdf
Edit 2:
Radiall R280220007, which is a fixed receptical, not a detachable connector as I thought. Oh dear, I must look very silly now.
Thankyou for your help!
« Last Edit: June 26, 2012, 03:50:36 am by McPete »
