Author Topic: Power for free the real way.......  (Read 3841 times)
Offline SeanBTopic starter
« on: June 27, 2015, 08:32:18 am »
Anybody care to translate, as the YT auto translate mangles Russian quite badly.......
Long line, high voltage power line nearby and light and radio in the home for free, using old electronics and some scrap to do it.
Offline Psi
Re: Power for free the real way.......
« Reply #1 on: June 27, 2015, 08:40:07 am »
Because a 20kHz flyback transformer will obviously work at 50hz and only 1 wire.
« Reply #2 on: June 27, 2015, 08:56:09 am »
Have you looked back and seen his microwave experiments, or the method to get worms for fishing.......
Offline george graves
« Reply #3 on: June 27, 2015, 10:43:34 am »
I think this is an old wives-tale. (nice video - glad to see Russia has after effects/CGI now!)
The original story went something like this.....
So the power company demanded that they put in huge high tension power lines across a farmers field. He protested, but "eminent domain" prevailed. The lines happened to run right past his barn.  So he did what any farmer would do.  He pulled out his mile long spool of copper wire (like every farmer has a mile of copper sitting around - but for the general public, it's plausible) and wrapped his barn in copper.  And then started stealing power from the power company! Untill the "man" shut him down.
BTW - I forget is magmatic field the inverse cube of distance, or the inverse square? - anyways - that barn would have to been right up next to them big old power lines.
« Last Edit: June 27, 2015, 10:46:20 am by george graves »
Offline dexters_lab
« Reply #4 on: June 27, 2015, 07:40:14 pm »
been subbed to kreosan for a while, i do like his adventures, but i have wondered if there is some, erm... artistic licence in some of his videos?
they certainly like sound effects
Offline Towger
  • Country: ie
« Reply #5 on: June 27, 2015, 07:58:48 pm »
It does not take much to light fluorescent tubes. I used to do it as a kid just wrapping cheap RG58 around one connected to a standard 4 watt CB radio.
Offline lapm
« Reply #6 on: June 28, 2015, 01:14:32 am »
Didnt Mythbusters do episode about this and even they with Hollywood tech could not get it to work in level where you could even charge phone with it...
Electronics, Linux, Programming, Science... im interested all of it...
Offline NiHaoMike
    • Facebook Page
« Reply #7 on: June 28, 2015, 02:47:27 am »
One story I heard was when someone soldered a hook to one end of a fluorescent bulb and then used a R/C helicopter to hang it on a power line right outside the bedroom window of someone he wanted to seek revenge on.
