What storage solutions have you found that works best?
For a through-hole resistors I have made my own storage system using PP-containers from cotton sticks. I decided to use E24 series. So I took 24 of containers and devided each to 10 partitions. I have used container covers to make dividers.
I decided to use following system: let's represent every resistors resistance in scientific notation (x*10
y). So {x} is number from E24, and {y} is number from 0 to 9 (it covers range from Ohms to hundreds of megaohms).
Every container represents {x} number. So I have 24 of containers.
Every container partition represents {y} number. So I have 10 of them in every container.
If I need 33k resistors all what I need is to find container marked as "33" and to take desired part from fifth partition (not fourth, because first partition contains 3.3 Ohm, second is for 33 Ohm, third is fo 330 Ohms, fourth is for 3k3 and fifth is for 33k).
(The left grid-style container is temporary. Those two on the right are normal. This foto was made during filling this two)
Similar organisation system is good for capacitors as well.
As for small SMD parts (including SMD resistors), in my opinion best way to storage it is to keep all parts on tape untill you really need it. Of course, if you got it on tape.
For a TO-220 (and TO-126) parts I've decided to make special bars for holding parts. One bar per one type at least.
For smaller through-hole parts in my opinion, if its not sitting on tape, it better to place it on tape! On a self-made tape! I use simple one-layer adhesive tape. Put some adhesive tape on a table (glue-side must be on top). Then lay your parts on it. Them put another strip of tape upon it (glue-side must be on bottom now).
I have found many of advantages of this tactic.
- When your parts is on tape you can put dozen of different tapes in one box. Then if you need a part of particular type you should just pull it. You will draw all your parts of same type. When different parts mounter on self-made tape are in one box, they can not mix with each other.
- You can put a lot of different parts in your pocket as well. It will not mix, it will not fall out and so on.
- If you need 20 of transistors of same type, you do not need to extract them all from your tape. You just need to cut your tape in right place. But if you then suddenly decide that you no more need this 20 of transistors, you can easily connect two tape strips into a one (by same adhesive tape, of course).
- If you have a really big amount of parts of same type, you can roll your tape onto a reel.
My self-made tapes of various transistors:
And some diodes:
