It is most likely a thermistor.
Thermocouple would have two different types of wires evident, generally with different color insulation.
A "one wire" sensor would probably have 3 wires (though it can work with only two).
A thermistor in a resistor bridge is the most likely thing here. Looking at the BOM for the printer (if open source) is obviously the best path.
